SOURCE: Tivo won't change my TV Channels anymore with direct cable
I re-did the guided setup in the Tivo under Messages & Settings/Restart-Reset System/Restart menu section in Tivo. Once I did that, it cleared this issue, even though I didn't have to change any of my settings thru this guided setup. I tried a reset alone first, but that did not fix it. Only this fixed it. We had lost both power and cable during a recent tree fall in a storm, and when both were restored, this problem started. I have a cable coax directly in the back of the TV (no cable box/IR etc) and the system is on a home wireless network. I actually have 2 identical Tivo's in the house set up the same way but only one had this problem. The other worked no different after the outage.
SOURCE: TIVO DVR : Won't Change Channels
Set up your infrared blasters connected from your IR port on the Tivo and by placing the two lead lights in front of your cable box so it (the cable box) can read the signal. Then go to Channel settings accessed through Tivo Central and follow the questions. It will ask you to change channels until the remote is working correctly. This all worked on a different "input" on my Mitsubishi TV (it has multiple inputs. I have the cable input on a different "input" to make it work. Hope this helps. Call TIVO tech assistance because they are the ones who talked me through this.
SOURCE: the tv will not turn on anymore-have a blinking
internal breaker, hopefully that xbox is plugged into a 3prong ac outlet. unplug the tv from electricity for a half hour and that circuit breaker inside should auto reset.
