Health & Beauty Logo
R
Rose Posted on Jun 16, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Husband 76 B.P. Is 100 over 55 he is dizzy and feeling tired, He was in Hosp . Overnight had temp.39.7 he has the shakes and is hot and cold?
Geoff White
Level 3:
  • Health & Beauty Master 1,948 Answers
  • Posted on Jun 17, 2018
Geoff White
Level 3:
Answers
1948
Questions
Helped
388146
Points
7024
It sounds like a feverish infection somewhere, but hard to tell at this range. BP is low. At his age he should go ASAP to your GP , who may order blood tests.
john h
Level 3:
Top Expert:
  • Health & Beauty Master 29,494 Answers
  • Posted on Jun 16, 2018
john h
Level 3:
Top Expert:
Answers
29494
Questions
0
Helped
7558837
Points
193449
Notify doctor of this NOT an online repair forum
3 Related Answers
Anonymous
  • 10 Answers
  • Posted on Jul 07, 2009
SOURCE: Help..my tire sensor blinks intermittently during hot weather.
dont trust the tyre pump when you pump them, up there never right one knock and it puts them out
BrianWren
  • 296 Answers
  • Posted on Jun 21, 2010
SOURCE: starts good cold.once hot runs crappy some black
Sounds like the choke is stuck shut.
Anonymous
  • 786 Answers
  • Posted on Aug 15, 2012
SOURCE: truck shakes
could be tires need to be balanced . try that.
1helpful
Car has been sitting overnight thermostat recently replaced as well as the temp sensor still reads hot
If vehicle reads hot when it sits overnight and is actually cold, there is an issue with the temp gauge... temp sensor... wiring.... . You didn't state year/make/ model so it could even be a BCM issue.
89 sidekick, solenoid clicks but car wont start
89, the dizzy loves to fail. it has a standalone dizzy until 1991.
so the ECU does not make spark on 1.6L , 1.3L is carb car.
the dizzy ignitor or VR devices like to fail hot.
check spark with it wont start bingo , bad dizzy, next?
Truck shakes
My miata shakes at 40 mph
Although you didn't say if it feels like the shaking is coming from a wheel, it sounds to me like you have a bad tire even though they are new. Take it back to where you got the tires and have them take a look. If they can't see anything, ask them to take it for spin.
1995 Lumina Van runs good and then wheels shake and doesn't accellerate good.
A shop didnt find anything? You have a suspension problem Lets start at the tires is there any mud or crude that affect the balance of your tire? What about wheel bearing is there side to side movement even with the rear,How about the upper ball joint and lower ball joint . a warp drive axle can cause this . If you are certain of there inspection with the suspension the problem is the torque convertor. If that stays lock up whoa you will be shaking like big time
On a 2001 saturn L series, 2.2 litre automatic. gas gauge doesn't work and the temp light blinks continuously while the temp gauge needle jumps continuously. i've checked the coolant levels,th
For car running hot and overheating issues, I suggest to you go through this help links. Click this link below and go through the troubleshooting procedure to take care of the problems: ----Car runs hot? http://howtobyme.blogspot.com/2011/11/car-runs-hot-in-traffic.html
-----------All types of car overheating problems and troubleshooting?
http://technoanswers.blogspot.com/2011/11/all-types-of-car-overheating-problems.html
Car freeze overnight and started overheating while driving?http://technoanswers.blogspot.com/2012/01/car-freeze-overnight-and-started.html-----------Engine Overheats and heater blowing cold?
http://howtobyme.blogspot.com/2011/11/engine-overheats-and-heater-blowing.html
Car overheats and Air blows hot at idle?
http://howtobyme.blogspot.com/2011/11/car-overheats-and-air-blows-hot-at-idle.html
--------overheating? http://schematicsdiagram.blogspot.com/2011/12/buick-century-overheating.html
----------Car engine Overheats and transmission starts slipping?http://schematicsdiagram.blogspot.com/2011/12/car-engine-overheats-and-transmission.html
----------This details will help.Thanks.
Mazda 6 V6 2005, at 58 kms/hr whole car shakes. Not from steering but feel it in my behind and it's the whole vehicle.Started when I bought the car new. Brought it back many times and trans. expert...
if the shaking is coming from the rear end, have you checked the tires to make sure you havent broken a tredd in the tire and make sure the tires are balanced correctly and one hasent lost a wheel weight and thrown it out of balance. and check the air pressure in them also. check all tires i hope this helps
1helpful
I have a 2003 Mitsubishi talent when I am driving ob the highway when I get to 60mph my steering starts to shake and Guatemala that shows if its hot or cold drops to cold it goes down to the C what does...
The shaking may be remedied by having your tires balanced
I have no idea what "Guatemala" means in this context
Sounds like you're asking about a temperature guage that is faulty or a faulty sending temperature sensor
Engine shaking in the morning
Try getting your tire balaced as you ight have a tire that has seperated from the inner wall, as it sits overnight it will cool down then when you drive it the rubber sofens and the vibration will improve. I have had water in the tire too but i don't think thats your problem.
hope this helps.
[email protected]
Top Health & Beauty Experts
Rob Hill
Rob Hill
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you a Health and Beauty Expert? Answer questions, earn points and help others
