SOURCE: KYOCERA KM-1820 COPIER
follw these steps, it should work
turn off copier.
open top toner cover.
turn copier back on.
when you see message "close top cover" press "system menu" button.
scroll up to "service setting" then press the # button, green "start" button and the "enter" button all at the same time.
then scroll down to "maint mode"
press "enter"
then enter 163
press" enter "
turn off copier then turn back on
close toner cover
you should be back in business
SOURCE: Kyocera 3900DN Error Code
F030 General failure
Miscellaneous failure with the main
PWB, other than F000, F010, F020,
F040 and F226, above.
Defective main-PWB
Turn the power switch off/on to restart the
printer.If the error is not resolved, replace
main PWB
SOURCE: kyocera mita km-2030 call service error
open the left side door and push in the drum unit firmly. it's the part above the waste toner
SOURCE: Error code 6000:0106504
This seems to be a fuser error. You need to take it to your local sevice agent for repairs.
