SOURCE: Hello, i have a vizio flat screen tv and i don't
Does the Bose have HDMI out? Does the tv have an HDMI socket?
If it does just connect them both together. All inputs i.e. cd, ps3 dvd etc will go into the Bose.
SOURCE: connection to TV by HDMI cable
The 625 is not a high definition receiver and therefore does not support hdmi. You can use RGB or S-video to provide a higher quality picture than the coax output. If you need more options let me know. Thanks for using Fix Ya.
SOURCE: Hello, Currently I have Vaio laptop connected
You need a 1/8 in cord on both ends. Normally, its an 1/8 inch audio connection in your tv to work with PC (the same connection as when you plug it in your comp) So u would need a wire that both ends are 1/8 inch (Headphone jack sized)
SOURCE: Purchased and set up both Vizio SV370XVT HDTV and
Try setting your cable box for Closed Captioning. Worked for me.
SOURCE: Buzzing noise coming from Vizio HD TV speakers
It ur Vizio tv,The power supply board is the problems.The transformers in the power supply board have gaps in the transformers.The high voltage curents flow that make that buzzing noise.
Vizio HDTV- Lips out of sync
Anyone with a new Vizio E601i-A3 60" or 70" HDTV that is
having audio "Lips out of sync problems" with a cable or satellite box.
On Comcast cable boxes (or others), here's what you need to
do: FIND MENU for AUDIO or HDMI setup on
CABLE BOX or Satellite Box.
FOR COMCAST
1. Turn on TV and have Cable box Turned OFF.
2. Press MENU on COMCAST REMOTE.
3. Go to AUDIO Setting OR HDMI Setting. (On cable or Sat.
BOX)
4. Change setting from Auto to L-PCM. (Turn off cable box to
exit)
This should resolve any "out of sync" lips to picture after
commercials on HD channels.
*This is a handshaking issue from the cable box to the Vizio
E601i-A3
