Frigidaire Fridge Model # FRS26HF7BB0. Fridge is making a low buzzing noise every few minutes for a few (15?) seconds. Freezer is losing coldness - temp inside freezer is reading 30 degrees. Vacuumed the coils and grill and turned the coldness up on the freezer about an hour ago. Still buzzing/temp still reading 31 degrees. Help!
That noise is typical when the compresor is trying to start but it doesn't , it could be the condensing fan motor that doesn't work and the compresor goes off on overload ; a common problem with this compresors is the relay (mounted at the side of the compresor behind a black plastic cover) goes bad , this you can replace is about $20 , and if still the compresor won't start you will need to put another one and this is an expensive job.
