SOURCE: Insert SIM Card message in nokia 6080 though SIM is inserted
May be its detecting your sim card properly. Check your sim card in another handset. Verify if its the propbelm with sim card not your handset.
SOURCE: Nokia N70 Insert sim card problem.......
i can solve this
if you want to format your memory follow this:
menu>tools>memory>then press options>from the list select format mem.card.
SOURCE: error msg on iphonethe sim
if you are trying to use another carriers sim on your iphone it will give you that message unless it's unlocked. If it's an AT&T sim just go to the local AT&T store and get another one. If its a corp. store there is no charge
SOURCE: Insert sim card problem in Nokia 6030
nokia6030 mobil is not conecting the network its showing insert sim card
SOURCE: My pantech matrix cell phone says insert sim card
This problem arises sometimes because the mobile is unable to read the SIM. May be you should fold a small piece of paper in the same size of the SIM and keep it on top of the SIM and then insert the Battery. I think this will solve your problem.
