about the cards their models must be not same that's why you don't get the soft copy of other pics on your computer ..or
For those of you with a Canon camera of the above models; there is a
firmware release that will make the autofocus work a bit better. Here are the links (a40,a30,a20,a10) http://www.canon.co.jp/Imaging/PSA40/PSA40_Adjustment-e.html http://www.canon.co.jp/Imaging/PSA30/PSA30_Adjustment-e.html http://www.canon.co.jp/Imaging/PSA20/PSA20_Adjustment-e.html http://www.canon.co.jp/Imaging/PSA10/PSA10_Adjustment-e.html
It mainly fixes the soft-focus problem with the second to last telephoto setting: In
case you haven't seen this problem, take an A40 and zoom to the
furthest optical setting (3x). Take a pcture; preferably something a
dozen meters away or so. Then just touch the button lightly to zoom back
one step (there are 7 zoom settings in total if I recall; maybe only
6); and take the same photo. When you compare these the soft setting of
the second photo should be apparent.
The firmware went smoothly for me and is fairly simple to do.
Consider NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive. Or you can use any photo cataloging program.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program.
First of all, do not save any new file to camera's memory card.
Take out memory card, and connect it to a Windows computer using a card reader. You should see memory card shown as a drive letter (like H:) in Windows Explorer. Download this camera photo recovery software http://www.asoftech.com/apr/ Install and open the photo recovery software, select the memory card, and click 'Start' button.
Because these a refills inks the Chip things they are full so you must
replace the cartridge with a new Canon one and the fault will go. If not just replace the chip with a new one!
A DVD player may not recognise JPEG, but will recognise MPEG, which is why the DC210 has the Photomovie facility to convert the still photos from JPEG to MPEG, but you can still get to see your still photos on your PC, because they are on the disc.
Here's how you do it.
The
disc has two folders - VIDEO_TS for videos and Photomovie and DCIM for the
still images. Inside DCIM there is a folder called 101CANON. Open this
folder to see the still images - they all have .jpg file extensions. It may be quicker to copy the 101CANON folder to your PC, and open the copied file on your PC.
Don't forget to rate this solution once you've tried it !
Yes it can, it should be under picture styles or something similar to that. However I find it better to take all my pictures in color and convert to black and white on the computer, which keeps my options open and gives me more choices for B&W conversion
