Question about HP Office Equipment & Supplies
I have HP Officejet 4630 error code OXC4EB827F. How do I fix it or reset it to default setting?
  • HP Master
  • 3,015 Answers
If the machine is not too old and still supported by HP I suggest you go to their support site and download the trouble shooting software
HP print and scan doctor
https://support.hp.com/th-en/document/c03286146
Posted on Jun 22, 2018
6ya staff
SOURCE:
Anonymous
  • 234 Answers
SOURCE: Error code 0xd05d010d reset power
Unplug the power cord from the All-In-One as well as the power outlet.
Plug the power cord directly to a wall outlet without surg protector. (if possible connect it to a different power outlet)
Before connecting the power cord to the All-In-One press and hold the # and no 6 button and then insert the power cord, do not release the keys until you see a message a reset (if the screen goes blank then release the keys and turn the power on)
Then check and see
Good Luck
Posted on Sep 17, 2008
Curtis Richner
  • 461 Answers
SOURCE: Want to set Draft as Default Print Setting
Under Printers and Faxes in Control Panel (Classic View) right click on the printer and select properties then under Printing Preferences set Draft and click OK - this will now be the default setting.
Posted on Dec 11, 2008
Anonymous
  • 20 Answers
SOURCE: HP Officejet 4315v Error Code 344*
1. issue may be with telephone line conditions,  try sending a fax at a different time 2. Disable Error Correction Mode 3. reduce thefax speed 4. try a fax test to  hp at 1888 473 2963
Posted on Jan 26, 2009
Anonymous
SOURCE: error code i hp 4255 officejet printer
have problem in my printer hp officejet 4255 oll-in-one it give message ERROR : 0XF0aF8005 pleas help me I can repair the priter if u can diagnose the error code
Posted on Mar 05, 2009
Ciprian Ciolacu
  • 107 Answers
SOURCE: I get *388 error sending faxes from hp officejet v40 over VOIP
Please check this:
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&dlc=en&cc=uk&docname=buu02549#Error386
Here you will se a lot explinations from hp
Posted on Mar 06, 2010
HP 4630 printer has error code oxc4eb827f
Welcome to the HP Support Forums!
I see that you're getting the error code: 0xc4eb827f on the front panel of your HP Officejet 4630 e-All-in-One Printer. I'd like to assist you today with resolving this error. The failure itself may be within the print system in your printer. Due to the error state there is only one support step that we can attempt, which is a Reset. Can you please follow the steps below.
Reset the Printer:
Without turning off the printer, disconnect the USB cable from the rear of the printer.
Remove the ink cartridges from the printer. *
Wait until a message to insert the ink cartridges displays. If you do not see a message within a few minutes, skip to step 4 to disconnect the power cord.
Disconnect the power cord from the rear of the printer.
Wait 60 seconds.
Reconnect the power cord. If the printer does not automatically turn on, press the Power button.
Reinsert the ink cartridges, and then close any open doors on the printer.
If you receive a prompt to print a calibration page, do so.
If you disconnected the USB cable, reconnect it to the rear of the printer.
Try to print.
Copy to Hp support.. hope this will help
Jun 20, 2017 | HP Office Equipment & Supplies
How do I make the text larger on my office jet 4630 printer
This is the font setting in the application.
Make sure the font is at least 12.
(I am assuming the default settings in the printer setup.)
Oct 25, 2015 | HP Officejet 4630 Inkjet Multifunction...
How do I fix TWAIN error? How do I fix Scan Gear error message cannot communicate with scanner?
you need to make sure that your printer is supported by TWIN , you can do that online.
Oct 21, 2015 | HP LaserJet Office Equipment & Supplies
How do i send a fax
User manual for hp officejet 4630
http://www.hp.com/ctg/Manual/c03909822.pdf
Chapter 6 contains all the setting details about fax.
The video showing how to send fax over telephone line
Oct 14, 2015 | HP Officejet 4630 e-All-in-One Printer
How do I copy 2 sided copy from 2 sided original on hp Officejet 4630 e- All-in-One Series
copy one side, then take copy and put back into blank paper try and then copy other side. trial and error will tell you how to put paper in paper tray but usually printed side up, top in
Sep 18, 2015 | HP Office Equipment & Supplies
What does error code OXC4EB827F mean?
Please make sure this printer is plugged into a direct wall, not a surge protector.
Next, follow this entire HP document on 'Ink System Failure' or a '0x...' or a 'C2...' Error Message Displays on the Front Panel.
Let me know if this document resolves your issue or not.
Jun 22, 2015 | Office Equipment & Supplies
Hp officejet 4630 will not work with remanufactured ink cartridge
most wont.. they require the original expensive replacement cartriges..
Feb 02, 2014 | HP Office Equipment & Supplies
Hp 4630 error code oxc4eb827f
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience.
http://electro-medical.blogspot.com/
Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Dec 04, 2013 | HP Office Equipment & Supplies
662 people viewed this question
Clive
Clive
Ekse
Thomas F. Schneider
