Boating Logo
John Alaveras Posted on Jun 25, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Hi I have a lowrance x48 fishfinder and transom mounted transducer, I also have a navman 5380i chartplotter. My question is can the transducer be used with the Navman 5380i chartplotter.
Daryl Gleaton
Level 3:
  • Master 749 Answers
  • Posted on Jul 02, 2018
Daryl Gleaton
Master
Level 3:
Answers
749
Questions
0
Helped
234275
Points
2170
  • I would think not as the resistance and transponder are matched to the unit.
3 Related Answers
Anonymous
  • Posted on Apr 30, 2009
SOURCE: navman 4500 fish finder w/transom mount transducer
I finally got an email reply from Navman. If the unit is less than two years old (mine is not) they will repair it. If it is over two years old, or if you can't prove that it is less than two years old, you can ship it to them and they will repair it for the low, low price of 355 US dollars.
Pretty nice of them since it appears these units are highly problematic isn't it? I am wondering if they guarantee their fix, or just have you on the hook for another 355 dollars later.
Good Luck Everyone,
Walt
Editor925
Dean
  • 285 Answers
  • Posted on May 29, 2009
SOURCE: lorance x25 and x48 configuration, same transducer imput to unit?
The answer is yes. The transducer will fit both units fine without any modification.
See http://primus.lowrance.com/support/resultDisplay.do?docType=1000&contextId=17%3A10.34&clusterName=ClusterPublic&docset=%2FDocuments%2FAccessories&linktosource=1&responseId=135ccbe2cfd4f608%3Adcb03b%3A1218e166f10%3A-5e14&groupId=4&answerGroup=4&score=984&page=http%3A%2F%2Fprimus.lowrance.com%2Ficr%2FAccessories%2FTransducer+Compatibility-Black-192khz.htm&result=5&excerpt=Transducer+Compatibility&resultType=5000#Goto10 for confirmation.
Please rate this solution on FixYa!
Anonymous
  • Posted on Jun 06, 2009
SOURCE: Transducer for LOwrance HDS-5
is the HST-DFSBL lowrence transduser combatible whith HDS-5 unit?
It works fine for about 20 min.then it starts beeping and alarms ging off sometimes it stops for a few min and then it tarts again I can turn it off and back on and it does good for about 20 min is there a...
I THINK what you're running into here is a poor power connection. (either positive or ground) It would appear to me that as the connection heats up, it is unable to carry the amperage needed to keep the unit running.
Carefully inspect, clean and lubricate with silicone spray the connections, (pay particular attention to the terminals at the power supply AND the fuse holder.)
Hope this is helpful.
-Steve
Why do I lose signal at higer RPM
usually a failing crank sensor, or cam but you would have an engine warning light when you lose your revs.
1helpful
How do i install elite 5 dsi on 14' tiller boat
Install the battery cables to the battery for the gas motor.
Here is a transducer installation guide for Lowrance, this is pretty standard for all transducers. Pay attention to how the boat sits in the water when trolling for level setting to match in water.
http://primus.lowrance.com/icr/units/HDS%20Installation%20Guide.pdf
If you don't have a PDF reader foxit reader is free.
http://www.foxitsoftware.com/Secure_PDF_Reader/
3helpful
2answers
Cant get the demo mode off my lowrance elite 5 dsi
go to menu click on system find simulator mode click off
2answers
Lowrance X-136DF Fishfinder Not working
Hello Keneth,
Is The transducer In Side the Hull Or Mounted On The Transom?
If Inside Remove It And Re Fit It Using Epoxy Glue Ensuring No Air Pocket Between transducer And Hull.
If transom Mounted Replace Transducer.
Hope this Helps
Gordy
4helpful
Navman 4500 fish finder w/transom mount transducer
Good Luck Everyone,
Walt
Top Lowrance Boating Experts
ZJ Limited
ZJ Limited
ExpressFiX
ExpressFiX
Are you a Lowrance Boating Expert? Answer questions, earn points and help others
