SOURCE: Which midi cable or USB midi cable should I use for Yamaha DGX 520 model.
It doesn't use a USB to MIDI adapter (such as the UX-16.) It has an onboard MIDI controller and uses a standard USB A-B cable. You just need to install the driver from the CD-ROM or here, and plug it in. You can get the manual from the same page or here. Setup is on page 99.
Hi
The normal reset is to hold down the highest note ( furtherst white key to the right ) at the same time as turning the instrument on. This will initiate a factory reset.
