SOURCE: Sony Bravia KDL-52XBR9
There is a error in TV.Count how many times blinking the red light.
Testimonial: "I also bought the Sony KDL-52xbr9 mine did the same thing with six blinks. I sent it back to to store. "
SOURCE: sony bravia kdl 32l4000 - color bars running vertically on screen
In most cases is the screen is covered with vertical lines all the way accross the screen then the T-Con module is at fault. The t-con board is replaceable without having to replace the entire LCD panel which would usually make it cheaper than replacing the TV. The part number I come up with is 1-857-213-11. Please take a moment to rate my answer. Thanks...
SOURCE: KDL-46XBR2 sony broke lcd screen
I had a kdl46xbr2 go out on me repair company said screen went bad and they told me warranty dept would not fix it cause the screen ran 2800. So now im in dis with them for a replacment tv and they wanna give me the xbr9 i want the xbr8. Theres a reason i spent 3500 on the xbr2 the bravia pro engine is in a nother class than the standard bravia.
SOURCE: WHERE CAN I BUY A SONY T-CON BOARD PART NUMBER
The part # you gave is the Control Board which sells for $668.79. The T-Con board your looking for is part of the LCD Display Panel and is not sold separately. I suggest you start by cleaning the ribbon cables from the control board to the t-con board. If that doesn't help then you had better take it in to a service center to verify which part is bad because there are no refunds, only replacement after you buy a board.
SOURCE: Sony KDL-52XBR9 has 4 horizontal lines approx 6
I have the same problem with my Sony KDL-52SBR9 52" HDTV LCD TV. Sony will not willing to fix this. Do you have solution? Samuel Lin
e-mail: [email protected]
