Category moved from 'Cars and Trucks' to 'Vacuums'.
If it was running okay before it went on charge and doesn't now, it is likely to be an electronic fault. They make it so that you can't run the vacuum whilst it is being charged. Try removing the battery for a few hours.
Nothing should go wrong, but when you are charging in the camera, with an USB cable, the camera can't be used. It supposed to be in the manual, but I don't know what camera you have, so I could not search on what page it is.
When you remove the cable after charging, the camera should switch on normal. If not, try removing the battery foe a few moment and reinsert the battery. (It is a reset)
It sounds like the charging port on your phone is broken. This could have happened a number of ways. Either by dropping your phone, putting the charger in wrong, or taking it out wrong. If you call HTC(866-449-8358) and it is still under warranty they will probably fix it for free as long as it doesn't have any water damage(http://www.ehow.com/how_4479971_check-cell-phone-water-damage.html). Otherwise you could also get a new phone.
If the cell phone battery is more than 3 - 4 years old thenthe battery could be worn out. Rechargeable batteries have a finite number of chargeand discharge cycles and will lose their charge capacity over time, i.e. won'tcharge to 100% and gradually the charge reduces until the battery won't chargeup at all. OR The battery shows a 100% charge but when the adapter isdisconnected the battery drops off to zero capacity in a very
if you move the cable around just right will it charge? if not u could have some kind of damage. did you drop it i would just try buying a new battery on ebay they are usually pretty cheap online. if you charge your phone alot and overnight. thats really bad for the battery
A red light on a blackberry means the battery is flat. (Requires re-charging)
If you are confident your battery is FULLY charged and your charger is working then you may need to take your handset to a repair shop.
Try charging up the battery whilst in the handset. Let it charge for 30 mins then try and switch it on.
Remember...Blackberry handsets take longer than most to start up.
It is not Necessary that these keys must be glow while charging..So Please take you mobile for a service to any Sony Ericsson service centre..Thank you..Regards!!
