SOURCE: I have a 2003 Chevy Silverado Ext Cab Z71, no sound is coming out
Seat belt and any warning chimes do not come from the radio, they usually come from a unit under the dash, what you are describing is probabl;y a blown fuse problem. I would checkfuses with a teat light as some fuses may not appear blown.
SOURCE: A MANUAL FOR SONY CLOCK RADIO MODEL NO ICF-C253
Here you go
http://safemanuals.com/user-guide-instructions-owner-manual/SONY/ICF-C253-_N
let me know if you need anything else.
Thanks,
Ekse
SOURCE: My 10 year old Bose wave radio quit working.
There's a line fuse inside the radio, mounted on a PC board. CAUTION:
disconnect the set from power before opening the case or poking around
inside. The fuse could be bad, but these sets are notorious for losing
the power transformer. If the fuse is ok then you are looking at a
$100 repair fee from Bose. You might want to check out the new HD radios -- better sound, MUCH lower price.
Bill B.
SOURCE: 13 years old Sony ICF-SW7600 not working
Sony radios of this era had notorious capacitor problems.... also several other brands were affected. These capacitors were underrated and the technology to make them was not at it's best back then. The cure is to replace the capacitors on the board with new electrolytics. About 28 of them need to be replaced but the big problem is to find someone to do this. the original capacitors are surface mount and must be removed and new radial lead caps put in their place, some are rather tough to get at and the new ones have to be placed carefully. My SONY ICF-SW7600 now works as new and maybe even better!
I have done this myself as I have skills working with surface mount capacitors. I offer my services to those who cannot find service for their radios. Please email me for details, I am not into making bucks on this, I just want to see these radios kept working and bringing enjoyment to their owners.
Good DXing Rod KB8DNS
SOURCE: Replaced factory radio one week ago with
sounds like its wired up wrong, remove the radio unplug the connector and remove the radio, then check all your fuses must have blown one when radio was installed, after that charge battery and with radio removed see if battery goes dead, if not recheck wiring to radio, common problem with vw aftermarket radio,they are installed wrong,good luck,
