Washing Machines Logo
A
Anonymous Posted on Jul 04, 2018
LG front load washer regardless of size or contents always goes unbalanced, fixes?
john h
Level 3:
Top Expert:
  • LG Master 29,494 Answers
  • Posted on Jul 04, 2018
john h
LG Master
Level 3:
Top Expert:
Answers
29494
Questions
0
Helped
7546835
Points
193449
Frame brace / bushing damaged -not properly balanced
5 Related Answers
Anonymous
  • 210 Answers
  • Posted on Jun 08, 2008
SOURCE: LG WM-2277HW Front Load Washer not working with ce showing
CE is an error stating that you have a problem with you board or possibly the stator on your unit. Either way your going to need service. You can ohm out your stator to see if it is the problem.
Check the back harness, maybe it has come loose, remove the back panel and it is the blue connector.
Sgt 48
Anonymous
  • 88 Answers
  • Posted on Jan 08, 2009
SOURCE: LG Front load washer LE error code
LE is a locked motor error. Not to worry as 95% of the time it is just a bad hall sensor (the motor position sensor). For your model the part number is 6501KW2002A.
You can order parts by your location by CLICKING HERE
ginko
Ginko
  • 19396 Answers
  • Posted on Mar 27, 2009
SOURCE: load starts banging like it is unbalanced
Check first the machine balance, to ensure the machine is at level and well balanced and that is not the problem.
If you already inspected springs and strut, then the problem is usually the drum bearing, or the drum bearing spider that has broken.
You can superficially check if there is a problem with the drum bearing by spinning the drum with the hand to check if there is excessive play.
If you found oil under the machine, check also that the support for the motor and motor gear box under the bearing is not damaged, and any of this part is banging again the chassis, this can cause oil leak, and machine shaking.
The most common is a bad bearing.
Anonymous
  • Posted on Dec 02, 2009
SOURCE: LE code appeares on my LG front load washer
A majority of the time when the LE code appears.. the Hall sensor in the motor is bad. Replacing it. Part # 6501KW2002A from MCM electronics... can help. Good luck.
Anonymous
  • 1937 Answers
  • Posted on Mar 12, 2010
SOURCE: Kenmore washer is unbalanced in spin cycle
is assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
If you look at the section on "Machine Base Parts" you'll see a number of springs and vibration pads.
It's possible that one or more of the springs or pads has come loose or broken.
In order to get to them you have to remove the cabinet.
Here is a description of how to do it.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=131&osCsid=90fdc122f6335c7c64f46f2ea1b1c887
Also see the Whirlpool Service Manual for top load washers. It has a troubleshooting section that describes the reasons for excessive walking or vibration.
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Repair%20Part%20List%20-%20W10114743.pdf
If it's not the springs or pads, you may consider that the "Agitator Cams" in the transmission are not raising the Agitator Gear high enough (about 1/16" ) when the washer goes into spin mode.
See the description of what the Cams do in the Service Manual.
We had the same problem, excessive vibration and noise during the spin cycle.
In order to solve that problem, :
Assuming that you know how to remove the cabinet, agitator (you don't need to remove the tub), pump, motor and transmission the agitator cam and follower use the same whirlpool part number 62580/01. This is a plastic set used to raise the agitate gear on the shaft.
Pull the transmission.
Remove the clutch (the spring holding the clutch to the spin pinion is a bear to replace.
Remove the 8 transmission screws carefully, the transmission is full (15 oz.) of 80-90 weight oil.
Remove the transmission cover.
Pull off the spin pinion.
Push down on the agitate spring and remove the spring clip. Note where is attaches to the main shaft.
The two plastic agitate cam parts pull right off. Don't lose the washer on top of the cams.
Replace the cams, washer, spring and clip, pinion, oil (assuming you drained the oil first), cover and clutch parts.
Line up the transmission so that the release cam on the brake drum will snap onto the clutch spring retaining clip and put all parts back in the washer.
The basic tools are screwdriver, small socket set with up to a 1/2" socket, vice grips or good pliers (to remove and replace clips)
It sounds a bit complicated but it really isn't too bad and (For a $15 part, saved buying a $170 transmission.)
Following is the Whirlpool parts list for their commercial washers although the consumer models use the same part numbers.
Why does it always become unbalanced in spin cycle?
Kenmore Elite Top Load Washer - Unbalanced Loads ...
www.shopyourway.com > Manage My Life > Questions
Recently, the "LF" code has started to display and the soak cycle will not complete unless I ... Kenmore Elite Top Load Washer - Unbalanced Loads During Spin Cycly ... Would a bad outer tub literally cause the basket to become unbalanced?
Fix Unbalanced Top Load Washer - YouTube
? 1:21
https://www.youtube.com/watch?v=cVZIGhULzg0
Jan 17, 2014 - Uploaded by Carpe Diem
How to fix unbalanced high efficiency top load washer. ... I am having a MAJOR problem with unbalanced ...
Off Balance load in spin cycle - Sears ... - YouTube
1helpful
I have an lg front load washer and on the spin cycle it vibrates very loud and seems not to be balanced. Washer is level and does this regardless of load size
there are 3 shock absorbers attached to the drum. they may need replacing. check out the videos on either applicancepartspros.com or repairclinic.com
3helpful
My WM1832CW front load machine consistently gives me the UE error code during the spin cycle regardless of the contents or size of the load. Its a direct drive system - so what could be the problem?
bad imbalance sensor. silly little contraption that sticks off the back of the drum. It is a plastic lever with a light sensor attached to the end. there is a hole and a bb that sits in the hole. when the load gets imbalanced, the bb gets knocked out of the hole and the light shines through the hole. the light sensor relays the error to the computer and it displays UE. I took the sensor apart, and put a piece of tape over the hole so the light cant shine through anymore. No more UE code. LG parts are very hard to find. I dont mess with them, but it was my neighbors machine. This will get them by until they can buy a new washer. good luck.
1helpful
LG WM0642H washer "excessive" vibration
sounds like damper rods are getting worn. they support bowl underneath.i think if u change them it should fix problem. is it noisy during spin?if u need more help please reply. please turn power off b4 working on it do not want any accidents.
My Lg washer is showing a code UE and then PF what can I do to fix this problem.
UE means that the load is unbalanced in my LG. The code PE means that the water sensor is malfunctioning and needs replacing.
1helpful
Ue error code on my LG WASHER
Hi there
hope this helps you .
UE - Unbalance switch error Unbalanced load is sensed three times during a spin operation. Open lid. Rebalance laundry load and close lid.
· Check wiring harness
· Check unbalance switch
· Check circuit board thank your for writing to fix ya.
Best regards Rich
17helpful
LG front load washer coded UE. what does that mean?
UE means unbalanced error. when you see this, it means the clothes are unevenly distributed in washer, it's basically unbalanced.
2answers
Error Message and Tub not spinning
UE is likely an unbalanced load or load is too large. Reduce the size of the load and your issue should be resolved.
Top LG Washing Machines Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
