Music Logo
S
Suzan Marie Ellis Posted on Jul 04, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Plugging in KPC10M to Fishman amp. - Fishman Music
rhodesworks
Level 3:
Top Expert:
  • Fishman Master 3,159 Answers
  • Posted on Jul 11, 2018
rhodesworks
Fishman Master
Level 3:
Top Expert:
Answers
3159
Questions
Helped
561775
Points
331463
We will need the model of the Fishman you're using to advise you.
1helpful
Fishman prefix plus on Martin OMC 15E buzzing when volume knob is turned and random shorting out sounds through amp
You have to get the volume pot cleaned and lubricated. If not a quick replacement should do.
I have a fishman classic 4t that the battery isn't making a connection, what can I do? Do I need to replace it in my guitar?
can you tell if there is a wire broken? if you know how to use a vom meter you can check to see if you have continuity if you don't then you have a wire problem & make sure that your battery is good.
Problems with fishman solo amp
Just boughtcSA220. The XRL on No. 1 channel not working. Tried to different mice.
1helpful
What's your problem?I have two Fishman amps.The older Loudbox 100 single channel and a Loudbox mini. I am trying to find the service manual for the older fishman as I have a fault with it and the
Fishman iis you best bet http://www.fishman.com
You can download the user manuals, they do have a block diagram, but the scan is pretty bad.
It may end up the person looking at it is going to need to rely upon their general knowledge.
My own suggestion is to pull the chassis out so you can work on it while powering it. And then work your way through the amp with either a signal source plugged in at the input, and with high impedance headphones with test lead ends, go through each audio stage carefully. until the fault is isolated. If it is not caps or the rectifiers in the power supply, faulty ground connections to chassis or faceplate, a faulty 4558 is most probable. The headphone approach is the fastest way to address this last one. If a different series of preamp chip is used, a good source for the IC datasheets in general is Digikey http://www.digikey.com and parts too.
1helpful
I bought a second hand Fishman LoudBox Performer. The problem is that the Aux-in for the headphone doesn't work. So sick... What can I do? tnx
I don't understand your question. The "Aux in" is just that an input that goes to the power amp. Please note that the Fishman Loudbox does NOT have a headphone jack so don't be disappointed as there plain isn't a headphone jack on this unit. I would recommend that you get a small headphone amplifier for the purpose... or even go to a thrift store and get an old stereo system that has a headphone jack and use that.
Where is the fuse located in the fishman solo amp
The fuse is inside and if it blows, there is something wrong that caused the failure and MUST be repaired as just changing the fuse MAY do additional damage.
Top Fishman Music Experts
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you a Fishman Music Expert? Answer questions, earn points and help others
