I have Dyson DC59. For the most part is has been going ok, however, recently it has been running out of charge 5 minutes into using it. It appears to be charging when on the dock, but once in use, dies within a couple of minutes. What life expectancy can I expect from a battery and does a 2yr warranty on the product cover the battery? 2. What is the difference between a v6 cordless stick and an Animal?, are they the same in power, capacity etc? Thanks Dain
SOURCE: iRobot 530 charges intermittently
Reset the Roomba: hold down "spot" and "dock/demo" for fifteen seconds, then release and listen for the tune. Then charge the Roomba overnight. The next time you run it, the unit should run longer. If not, call support and let them know you may have a battery problem. 1-877-855-8593 (I strongly encourage you to have the Roomba with you if you call.)
SOURCE: I have the same problem as steve967 The dyson
Dear Michael_Stad,
I am going to sound like a broken record but here is my same answer to another person with the same problem.
I have I had the same problem with my Dyson DC16, where it only runs for a few
seconds at a time with each trigger pull. My husband called Dyson
(Canada) and without hassle they shipped us a replacement part which I
just received this morning. The replacement part sent to us is: DC16
Main Body with Rating Plate. It is also under warranty for 1 year. The
great customer service makes up for the flaw in the machine. Also,
Dyson is aware of the problem. Hope this helps.
SOURCE: My dyson DC16 constantly shuts off even when
Hi its Darran at Dyson.
From your description of the problem, it sounds as though there is a problem with the battery.
Your DC16 will have been supplied with a 2 year guarantee. If it still within this period, please contact our Helpline on 0800 298 0298. However if your machine is no longer covered, a replacement battery can be purchased via our website at www.dyson.co.uk/store.
Kind regards
Darran
Dyson Customer Service
SOURCE: I have a iRobot 4150 and have recently
Yes, a common issue with the cleaning head module, chm. You will need to diassemble the Roomba and remove all debris from the CHM. Also take a look in its gear box.
SOURCE: dyson dc 31 was working
check all conections are clean on the battery terminals,this link is for the manual,
http://media.dyson.com/downloads/UK/floorcare/Manuals/dc31_origin_manual_uk.pdf
