I had to disconnect the cables in back when I got rid of my entertainment center. I sort of guessed on re-connecting it but now I only get black and white so I obviously did it wrong. Can you help? Also does this model allow for a vhs/blue ray player?
It has an HDMI socket at the back for connection of the blue ray.
There is a manual for the model
Mintek DTV 265 Owner Manual
SOURCE: Problem w/ "Cable In" connection socket on Mintek DTV-373-D 37" HDTV
Just contacted QVC and was told by customer no service that they had no information at all on Mintek. Furthermore, I was told that the warranty would be covered by Mintek and not QVC. I must say I did find that a bit suprising. I expect better of QVC. Purchased the same model in November of 06. None of the buttons on the TV will repsond and it has a dvd it won't eject. If I have to pay for service that's fine, but I'd at least like to try to see if it's still under warranty.
SOURCE: I need remote code for Mintek LCD model 260
Use toshiba code 0156 that should turn on the mintek tv on
SOURCE: no owners manual can't get new blue ray dvd player to work on tv
Here is the manual:
http://www.hdtvsolutions.com/pdf/JVG%20HD52G56G.pdf
When using the HDMI connections you may have to tell the DVD to output to that port. Also you may have to connect additional sound cables from the DVD output to the TV.
SOURCE: Blue Ray connection to Belkin G router
your wireless router is encrypted. To remove encryption, go in your computers web browser:
http://192.168.0.1
That will take you to your LAN Administrator.
Follow the simple wireless setup for an unsecured connection or setup your blue ray connection and create your own passphrase or WEPKey.
Hope that helped!
