Question about Hoover Washing Machines
Hi, I have a hoover dynamic mega which has power to it but when we try to operate it, it just hums and nothing else
    Top Expert:
  • Hoover Master
  • 53,770 Answers
Motor nor spinning
could be a seized bearing , jammed impeller blades or start /run capacitor or a burnt out motor windings
Posted on Jul 07, 2018
Anonymous
SOURCE:
Hi what does e11 mean on my hoover dynamic 6+5 wdyns 654 d mean pls?
Code E11 indicates an open circuit between the heater and the control board. The code also can indicate damaged wiring between the sensor at the top of the drum and the control board. The wiring can be damaged by drum rotation.
Feb 09, 2015 | Hoover Washing Machines
Mega pump not working
try when off to remove back cover on motor then try to turn motor shaft by hand then try to turn on might be rusted
Jul 21, 2014 | Hayward Sp2607x10 Super 1 Hp Swimming Pool...
Internal fuse
no they dont, you can check continuity down to the board and also look on the board for any blackening caused by shorting iut
Apr 07, 2014 | Washing Machines
Hoover DYN8163D8P pump just hums !
if nothing wrong with pump, check drive motor
Mar 31, 2014 | Universal Supco PRO ERP Washer Washing...
Hoover HDV 7 FM tumble drier. The drum is not turning (its making a loud buzzing noise like its trying to get going) and the filter light is on, although that is free from fluff. Is it time for a new drier...
sumanth m 's answer may well be correct because I have the same dryer and it has the same problem. I got a massive electric shock off mine and so I think the buzzing is a protection measure against a short circuit
Feb 15, 2011 | Hoover HDV7FM Electric Dryer
I own a Hoover Steam Vac Plus w/ Rotating Brushes (model#F5871-900), when I turn on the power I hear a medium-loud hum coming from the motor area and nothing works. What could be the issue?
the motor sounds locked up. Water gets in there and rusts the pieces together. The motor could be replaced, but probably not repaired.
Jul 04, 2009 | Vacuums
Was using the SteamVac and it just stopped doing
Bad news! The humming is the pump so it is still good, but that means either the ac to dc converter is bad or the motor went up. The good news, neither would be your fault.
Apr 16, 2009 | Hoover SteamVac F5914-900 SpinScrub...
Problems getting Mega CD to work...
I just got a sega mk-4102a and I can not get it off of the cd to work with the regular games help.
Feb 22, 2009 | Sega Genesis Console
Hoover steam vac dual v makes humming noise and nothing else.
Is the overfill valve (the yellow thing) in the waste container stuck in the up/full position? Maybe it just needs to be rinses well to avoid it being stuck and shutting off the vacuum portion of the cleaner.
Oct 09, 2008 | Hoover Steam Vac Dual V w/ SpinScrub...
Washing Machines Logo
27 people viewed this question
Top Hoover Washing Machines Experts
peter gittos
peter gittos
Gerry Harvey
Gerry Harvey
Poppa Maddo
Poppa Maddo
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
