I have the same problem and i did everything the code SC 491 still appears
Possible fixes from previous FIXYA question.
Use Comment menu to add information.
For example, what model Ricoh printer is it?
Have you replaced toner recently? If so, was it Ricoh original or not?
http://www.fixya.com/support/t26593905-printer_ricoh_sp_210su_service_call
Printer Ricoh sp 210SU service call error SC491 using compatable cartridge...
SOURCE: Ricoh Aficio SP C420dn Printer. The printer at
sc491 is a high voltage output error. Combined with your jamming issue, it sounds like a possible electrical problem somewhere. A good first step is to turn the machine off and unplug it, then take off the covers and reset any connections or cables you can get to.
If the problem persists, you should have a service technician take a look at it because it might need a board replaced.
SOURCE: wat i can do with my printer ricoh aficio sp c420 dn
Good afternoon Omar, my name is steve.
This error code can relate to one or two things.
1. PCU Photo-Conductive Unit is bad or needs to be replaced.
2. A defective High Voltage power supply board.
If it has not been serviced in awhile,and no user supplies other than toner has been installed in it, I would consider the first option.
I hope this assists you, best regards,Steve
