SOURCE: self deleting emails
Actually they are right but they are only telling you half of the
equasion. Here is what is most likely going on. I'm about 80% sure.
Norton antivirus is a very weak antivirus system. The only thing it
catches is the common cold. Now as for outlook. Yes outlook is very
vulnerable to Virus attack. I use Thunderbird if I ever use a program
for E-mail. I use Gmail or Yahoo myself but you can continue to
frustrate yourself with programs like Outlook if you like. If you must
use antivirus to protect yourself from Micro$oft then use Avast, Spybot
1.5, and Clamwin. You will need to configure them properly to get them
to work.
There is another way. You can stop using Micro$oft products and
download a Free Operating System that does not get viruses or get
fragmented. It also comes with Thunderbird. It's called Ultumix.
If you want Ultumix do the following:
If you have a Desktop PC connected directly to the internet (not dial up) and a DVD burner I would recommend you go to www.mindblowingidea.com, click Ultumix, and give it a try by saving the Torrent Download Link. Then go to www.download.com and install uTorrent. You will also need to go to www.burn4free.com
and install it as well. Make sure to open burn4free after installing it
as well and select English. Then you may close it. Open the torrent
file you downloaded in uTorrent. After you save the .iso file to your
hard drive (this may take an hour or a day) right click on the .iso
file and click burn4free and then Burn ISO. You will need a DVD-R or
DVD+R in your DVD drive. DVD-R is recommended. After this reboot your
computer and make sure to boot from the DVD drive. You may need to
press additional keys during start up to get this to happen. You will
see a menu that says PCLinuxOS 2007. Select LiveCD and press enter
(this mode will let you try Ultumix without installing it on your hard
drive). Now it will ask you some questions about your computer like
what language you speak. You will most likely use Ethernet as your
internet. Now you will see a screen to log in.
To try Ultumix without installing it to see what it will be like click
on Owner and then type owner all lower case in the password field and
press the enter key on your keyboard. Please note that it will run much
slower than normal in Live Mode. When you install it it will run much
faster. If you try the programs on the desktop and like them you may
want to install it. We will get to that later. Open the icon marked
internet and use it to get to www.hotmail.com. Get into your e-mail. If
that works you should be happy. At this point I would like to point out
that even though this system can't get viruses or fragmentation (unless
you fill the partition over 95%) Firefox can be affected by some
spyware and or trojans. If this should occur you simply click Tools
> Clear All Private Data > check everything > Clear All
Private Data Now.
If you want to install this on your computer you can also leave Windows
on as well but you will be asked if you want to run both during setup.
Click start and log out. Now click the root account and type in root
all lower case. Click Install PCLinuxOS. Go threw the wizard and follow
the instructions. You have the option of resizing your Windows
partition and using the rest for Ultumix or erase everything and start
over. Ultumix can run most windows 95, 98, and 2000 programs in WINE.
You will also find that it can run some XP programs as well like Office
2003.
Have fun. If you still want to live with Micro$oft software reply to me
again and I will walk you threw the painful process of protecting your
computer. You will need to repeat this process I give you every 12
months or less to keep your computer running. You should also be told
that in 6 months Microsoft is planning to stop extending service to XP
users.
SOURCE: iPhone 3G-Email in inbox deleting after 7 days
Have you checked your email through a method other than the iphone to see if it truly is gone? The phone will only display so many messages at a time, maybe your previous ones are just "dropping off" the bottom of the list. If that's the case then they're still on the server, just not visible on the phone. You can view more by going to Settings>Mail,Contacts,Calendars>Show. Hope this helps.
SOURCE: How do I delete text messages from Inbox on Motorola V220?
first press menu, select messages, then press menu button again, scroll down to cleanup messages, select, then scroll down to which box you want to delete and select. done!
SOURCE: i accidentally deleted all my emails from my inbox
It's possible, if it's been less than 24 hours since you deleted those emails to recover by filling out this form.
If using Classic:
http://help.yahoo.com/l/us/yahoo/mail/cl…
If using All-New:
http://help.yahoo.com/l/us/yahoo/mail/ya…
If more than 24 hours, and the Trash folder has been emptied, there would be no possible way to retrieve deleted emails.
Try to make a habit of NEVER emptying your Trash folder. The emails in that folder are deleted periodically by Yahoo!, so there's no reason for you to take that step.
SOURCE: SECURITY ALERT! Zynga Poker sent you
Go to your email [email protected] and find email from facebook that has subject something like "Facebook login using an unknown device"
A new unknown device logged into your Facebook account (Saturday, September 17, 2011 at 12:15am) from Dallas, TX, US (IP=75.88.28.66). (Note: This location is based on information from your ISP or wireless provider.)
Was this you? If so, you can disregard the rest of this email.
If this wasn't you, please follow the link below to protect your Facebook account information:
click on link shown and follow instructions
