SOURCE: My Compaq presario c500 won't turn on!
Sorry to say but your power chip has failed. M/board replacement required
SOURCE: the lightning bolt on my hp touchsmart tx2 flashes
that means your laptop has no power so your battery is dead which would explain why it shut down on you, and that means its not charging so it would either be the adapter or the port on your laptop
SOURCE: My iphone 3gs won't turn on. If i plug it into
Sounds like you have at least a broken battery. Apple should give you a replacement. If you're out warranty, you can try to open it and replace battery. If that fails you need a new logic board. You can get the part at iPad Repair and there is a guide that shows you how to open a kindle and install parts at iPad Repair Guide.
