You can order convergence amps for the unit. If you open the unit and find that there are STK392-110 in the unit, you'll want to order STK392-150 to replace them with as they are less likely to fail.
You can always open the unit and check the convergence amps to see what part they are and then Google that.
Replace convergence IC's (both) STK392-560 and any open pico
fuse device 3.15 amp soldered-in....moderate to above-average
technical skill needed...................T.
I have the same problem and have replaced the entire "D" board which has the convergence amps on it. The problem remains. Any other suggestions? This first occured when we turned on the tv. Worked fine the night before.
