SOURCE: Insignia Flat Screen TV - no cable signal
Hi, need some help here. I have a flat screen tv that will not go on. Its not even 2 years old. Yet I had to keep trying the wall outlet to get it to turn on. Now it won't go on at all. The tv light use to be blue when it was on. Now its pink? Should I ask santa for another, or can this be repaired without too much fuss/cost? Thanks!!!!
SOURCE: Programming Scientific Atlantic remote to work with New Dynex TV
dynex is bestbuy's product try emerson, mine is working with emerson codes
SOURCE: Universal Remote Code for Dynex 20" TV/DVD
I just bought a 32" dynex lcd and saw that i couldn't program my two $5 ge remotes to work it. From reading in this forum and others I'm not the only one with the problem, I thought I was stuck with only the dynex remote. But the dynex website tells you how to get universal remotes to work,
It tells you to try the codes for Orion, Emerson, Memorex, Sansui, Sylvania, Zenith. The second orion code worked for me. both my ge remotes look and work the same but one uses a four digit code and the other uses a three digit code. I used 0135 on one and 135 on the other. There is a good chance that if you try the codes for the brands dynex lists you will find one that works. The 0135 or 135 might work for most dynex tv's.
If you have a ge remote and haven't programmed it for volume punch through you might try it. It allows the tv volume to be controlled using the ge remote even when it's set to something other than tv.
SOURCE: I need a universal remote
I can confirm that the 0441 code does indeed work for the Xbox 360 Universal Remote. I just programmed it and it works perfectly. Thanks to the person that first posted that code!
SOURCE: DYNEX DX-LCD32 tv stand
Best buy has the stand you are looking for. I broke my stand the day i took the tv out of the box, darn it. $16.99 @Best Buy
