Did you get the right style of battery? Maybe your charger isn't working properly.
To remove icons, you usually touch the icon for a few seconds till the icon or the phone vibrates, then there should be a trash can to drag to. I don't know if that would work on your flip phone though.
Do the one two three method. While the phone is still on, remove the battery. Once it is removed, hold down the power button for ONE minute. This will drain any remaining power with the battery removed. After one minute of holding down the power button, replace the battery and see if it is still black, if it is, repeat only this time hold that power button down for a full TWO minutes and again put the battery back in and see if that fixes it, if it doesn't then do the same for a full THREE minutes. Basically you need to drain any remaining power from the phone before putting the battery back in to fix the problem. Hopefully this will fix your problem.
Yes! Buy or borrow another Alcatel 995 phone and remove the battery from the broken one and insert it into the replacement and charge then swap into the broken one!
1.Check the device's battery level for at least two bars of strength. 2.If the battery level is low, charge the battery. 3.If the issue is not resolved, remove the back cover. 4.Remove the battery. 5.Wait 10 seconds. 6.Press and hold the W key. 7.While pressing down the W key, re-insert the battery. •The device restarts and after approximately 15 seconds, the 'Recovery' screen appears •Release the power button but *continue holding the home button*, for another 30 seconds. Step Thanks
