If pump ok possible bad pressure switch or flo switch or temp sensor
If it is that tod you can also go to the pet shops and in the fish section they sell replacement parts for the aquarium pump you can probably find the right size.
Means temp to low and the last link is the answer from intex they stat to unplug system then replug but when the pump goes that causes same code since no water flow no water flow your pump has failed these pumps are a magnetic with a small ceramic rod to hold it in place the ceramic rod breaks and stops pump -- intex doesnt sell parts or replacement pump ---easy fix is to go to lowes they sell a brass rod about $4 or home depot and in welding isle is a package of brazing rods [[ brass ]] with a flux covering $ 10 dollars clean the flux off and measure rod about 3 inches is needed How to repair Intex PureSpa pump E90 Error 90 Intex Pure Spa E96 slow reset solution these links can assist http://www.intexcorp.nl/faqsup/pub/FaqSupportServlet?action=openFaq&qid=608&lst_prd=853&lst_subcategory=854&frmcontact=
