SOURCE: Bernina 1530
You may just need to clean it. Many times when people use hand lotion or other things oil etc. it gets on the ball and interferes with the board. Try cleaning the ball with cottonball and alcohol. It really makes a difference.
Hope this helps.
Rick
SOURCE: [email protected] needle on my Bernina
This sounds like you have the machine in bobbin winding mode, just refer to your manual to take it out of bobbin winding mode. I'm not familier with your exact model, but the is typically a lever, or button that is used to wind bobbins, so the needle doesn't keep sewing without the bobbin thread in place.
Please rate my solution thanks
Have you loosened the top tension?
