Question about Ricoh Office Equipment & Supplies
I have a Ricoh SP 210su model problem displayed service call SC 556
    Top Expert:
  • Ricoh Master
  • 1,903 Answers
Code SC556
Description : Temperature deviation error (Fatal Error)
Causes : More than 1 degree Celsius temperature difference (between Center - End thermistor) is detected for 1.5 seconds 5 times in a row.
Remedy :
- Check Fusing thermistor position and it's harness connection
- Check the input voltage if it's out of the limit
- Replace Fusing unit
Posted on Nov 09, 2019
    Top Expert:
  • Ricoh Master
  • 30,577 Answers
That is a temperature issue with the fuser.
Posted on Jul 19, 2018
6ya staff
SOURCE:
quennie732
  • 422 Answers
SOURCE: Ricoh Service Code error - Service Code SC-300
I am a Ricoh tech and my service manual doesent have a 300 code,
Posted on Jun 18, 2009
Anonymous
  • 58 Answers
SOURCE: Service Call SC 553 on Ricoh Aficio SP C811DN
553 is:
Heating roller overheat (software error)
The detected heating roller temperature stays at 230°C or more for 1
second.
�� Defective PSU
�� Defective IOB
�� Defective EGB
These codes related to the fuser a designed to prevent a fire
I would recommend haveing a tech look at it
Posted on Feb 26, 2010
hinto
  • 13 Answers
SOURCE: service call sc:543 for Ricoh Aficio 1515mf
plz do like this after again it shwos same then need to replace parts thermister,and thermal fuses. press the yellow 107 red and hold the red for two mints it shows copy sp.......like switch off on
Posted on Sep 19, 2010
rhico
  • 170 Answers
SOURCE: sc 556 for ricoh aficio
check the fusing unit thermistor,thermoswitch &heaterlamp
Posted on Nov 22, 2010
andy37718
Andy Bell
  • 28 Answers
SOURCE: My ricoh sp c811dn suddenly started displaying the
Here is a way to reset but make sure you follow the instructions correctly.
turn off machine
press online and escape buttons together whilst turning on machine,
when display comes up wait till three options are listed, use arrow button down to select engine, use arrow right to select mode(5.mode) and ok, left arrow to 5.810 SC RESET. OK. PRESS OK AGAIN AND THEN EXECUTE AT BOTTOM OF SCREEN.
Turn off printer and wait ten secs then turn back on.
If only temp error this should reset and start up again, Good luck
Posted on Jul 08, 2015
WHY THIS PRINTER IS SHOWING SERVICE CALL SC491
Unknown if this is the same model printer or not, as you question doesn't say.
You can add information to a question for free by using the Comment menu.
FIXYA is a free service. 6YA is a paid service as far as I know.
https://www.fixya.com/support/t26593905-printer_ricoh_sp_210su_service_call
Printer Ricoh sp 210SU service call error SC491 using compatable cartridge...
Jul 13, 2018 | PRINTER Office Equipment & Supplies
Service call-sc491
Possible fixes from previous FIXYA question.
Use Comment menu to add information.
For example, what model Ricoh printer is it?
Have you replaced toner recently? If so, was it Ricoh original or not?
Jul 10, 2018 | Ricoh Office Equipment & Supplies
Ricoh sp 210 printer showing error sc 556
Make a phone call to your Ricoh service rep and report code SC 556.
Mar 27, 2018 | Ricoh Office Equipment & Supplies
Printer Ricoh sp 210SU "service call error SC491". using compatable cartridge instead of Ricoh original. Service centre suggests to change the cartridge to solve the issue. any idea else pl share me
SC491 on a Ricoh SP 210SU is a code for bias leak.
The machine detects that a bias leak has occured from the drum charge, development charge or transfer charge.
PWM signals are sampled at 20 msec. intervals. This SC is issued if 10 PWM samplings within 200 msec. are abnormal.
• HVPS (high voltage power supply) harness loose, broken, defective
• HVPS board defective
• AIO terminal defective (the terminal for the toner cartridge)
• Cycle the machine off/on
• Check all the harness connections of the HVPS
• Check spring-loaded AIO terminal installation behind the HVPS.
• Replace HVPS.
Usually this error is related to the cartridge. Some manufacturers of compatible cartridges will replace the cartridge with a new one.
At least they should give a discount based on how many pages that was printed before it failed.
I have not seen this problem with a new genuine Ricoh cartridge.
It is important that the cartridge is not refilled more then 3 times. There is no counter on this, and companies that refill cartridges they collect (with unknown number of cartridges) may have problems quite often.
May 11, 2017 | Ricoh Office Equipment & Supplies
How do I solve the sc 542 error problem on Ricoh aficio sp 3510dn printer when it does not have an online button or a number keypad?
You need to switch the power switch off.
Hold down either the online & escape or stop/start & escape while switching the machine on.
The machine should start up in service mode.
Select 1 for service mode
Select 5 for mode
Scroll to 810 SC reset and select enter
Select execute.
Switch machine off and on again.
Jun 22, 2016 | Ricoh Aficio SP 3510DN
Copier problume.
return SP1-902-1 to 0. Then, the SC will
be cleared.
Sep 23, 2008 | Ricoh Aficio 1085 Laser Printer
Open Questions:
523 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
gggg
Adorjani Laszlo
quennie732
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
