The volume was previously absent an new speakers were fitted but the volume still does not go higher.WHY. Please help Petrose in RSA
SOURCE: Speakers cutting out at higher volume
Check the power /voltage printed at back side of speaker ,test w/ volt meter /if supply not enough current to drive the amplifier.The sound are very low and humming.
SOURCE: speakers playing low
open the disc tray and press setup and the speaker volume option will activate and also turn off the night mode for louder sound
SOURCE: Volume on surround sound speakers
Most receivers you can adjust the different chanel levels. If you refer to the manual on adjusting chanel volumes in surround sound mode.
SOURCE: Home theatre but TV without audio outlet
I would suggest that you smash
Philips HTS w/a hammer!
I had better sound from TV alone! Only 2 speakers put out sound from TV. Recordings from DVR can not be heard very well w/all volumes at max. System sucks! You get what you pay for! $2500 LCD TV sounds worse w/Philips HTS than my son's $300 TV! ALL cables hooked up as instucted!!!!
SOURCE: Hooking up external speakers to Sansui HDLCDVD320
I'm sorry, but the Sansui HDLCDVD320 has no analog audio out jacks. If you have a cable or sat box, etc, you might be able to get audio from their outputs. I hope this helps you.
