The power supply board showed 3 supplies all 13.2v going to the mains bd. I only measure 10 volts at 2 of these and 0 volts at the third. that is with the cable to main bd disconnected or connected. so if the bd is right should be 13.2 I would think power supply bad. also disconnected the wires from the power supply to led's and same thing
SOURCE: I have a LG 42LE5300 Led tv when I turn the tv on
if you are getting the logo and snow , I think you are on the wrong channel for programming
SOURCE: Tv cycles on to LG logo and back off continually when plugged in.
bad power board
Testimonial: "Ordered a complete set( main,power and logic board) for just about $30 dollars more than just power board. Waiting for it to arrive to see which component is bad. Will inform @ later time"
SOURCE: No back-light on LG LED TV
That means dead transformer supply chain. Replacing search not possible, donor Yes
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis. http://electro-medical.blogspot.com/
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
without testing then you might as well replace them all.
