Question about Fisher and Paykel Washing Machines
My GF’s Fisher and Paykel washsmart WA70T60GW1 will not turn on. Power point is okay. Any ideas appreciated
    Top Expert:
  • Fisher and P... Master
  • 55,370 Answers
Could be a defective power switch or control board
Posted on Jul 22, 2018
6ya staff
SOURCE:
Anonymous
SOURCE: Fisher & Paykel Smart Drive 601 - won't turn on
Hi I Have this washing machine (FISHER & PAYKEL Smart drive 601) hasn't been turn on for 4 yrs. now I'm going to use it coz my other machine broke.when I turn it on ,at starting it only distribute a little amount of water then it span the drum slowly.after about 5 mins. The lights of cold and hot keeps blinking and beeping.sounds like an error beeps .The power and all the light button still on except the cold and hot lights keeps blinking then just stop workin. can u help me what the problem could be.
Thanks
Jaf
Posted on Oct 07, 2008
Anonymous
SOURCE: Fisher & Paykel single drawer dishwasher F1 flashing.
F1 indicates a problem with the Flood sensor. I cleaned all the filters etc. removed the drawer viewed under the drawer, it was dry. There is nothing further I can do, so called the Appliances repair person and booked an appointment for him to determine if an outlet hose is blocked or has a hole in it or whatever. Thanks for all the suggestions Blokes. I'm technically challenged. Happy New Year
Posted on Dec 29, 2008
Anonymous
SOURCE: fisher and paykel 7.5 smartdrive washing machine, no power
If there is power and all your lights are lighting up but you get no responce from the machiene eg no spin, water filling, wash cycle or drain then it will be the sensor for the lid it will have coroded but this is an easy fix , I hope this helps
Posted on May 17, 2009
Linh Thanh
  • 784 Answers
SOURCE: Fisher Paykel dishwasher drawer won't stop.
Let's go to diagnostic test mode to see if you can retrieve the the actuator hence the tube out.
1- Press Lock button and start/pause key until the display showing up.
2- Press Power to show HO.
3- Press start button to advance the display until you see P2 for draining, if you pass, keep doing it to get it back in a loop.
4- When at P2, press lock to turn on, press a again to turn off.
5- Listen to the sound of the pump. If you hear nothing that means the pump is dead or stuck.
6- The Motor has 2 directions: one for, Rinse and one for Drain. When you done with the diagnostic, press the power button to get out of the mode.
7- If this is the case, unplug the power then remove the rack, the bottom stanless steel plate with holes then take out the rotor to clean up. It is a good design the stator is outside of the tube, so you don't have to worry too much about the complication.
8- Make a note of all the positions so you can put them back the same as they were. Good luck
Posted on Sep 09, 2009
Anonymous
  • 60 Answers
SOURCE: fisher and paykel washer doesnt turn on. no power
There are solder in slow burn fuses located on the circuit board that can burn out if the pump gets clogged or broken and some other reasons that you can buy from Mouser electronics using p/n (mouser) 576-37416300410 or Mfg p/n 37416300410. The fuses are reddish, round cylinders about .5 inch high and wide. Anyone who can solder can easily fix this. Be sure to tag any connections that you remove although all you need to do to get the circuit board out to work on it is remove the small rubber hose and 2 electrical plugs connected to the board through the outside cover. There is paperwork inside the head of the machine (and there is the circuit board) with fault codes to help you determine what your specific problem could be but I had a no power problem recently and replacement of these 2 fuses fixed it. Let me know if you need further help!
Posted on Nov 22, 2009
Fisher & Paykel washsmart washing machine model wa1068g1 was displaying error PUE-F and now will not switch on there appears to be no power to the unit
Pump Impeller is jammed cannot turn
has over-current power supply.
Small black chip near the small transformer has blown.
May 23, 2017 | Fisher Washing Machines
Is it possible to reduce the washing time on Fisher & Paykel 10kg washsmart machine? The quickest wash is 35 mins.
NO
the wash time is set in the program board and that time is what the manufacturers consider necessary for a clean wash
Sep 19, 2016 | Fisher and Paykel Washing Machines
Fisher and Paykel C240B refrigerator has stopped working.
Rebekkah i sugest you phone a technician to sort out whats wrong.
Jan 17, 2016 | Fisher and Paykel Refrigerators
Can you swap a hot inlet hose to the cold tap on fisher and paykel WA70T60GW1
Hoses are usually the same, but do you mean you want to put hot water into the machine through the cold inlet? A lot of water is used in rinse, and this would raise your hot-water heating bill a lot.
Sep 08, 2014 | Washing Machines
Fisher and paykel 8kg washsmart
check the water pump and hoses make sure it is not stopped up
Washing Machines Logo
303 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Gerry Harvey
Gerry Harvey
jimorris77
peter gittos
peter gittos
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
