SOURCE: SC DV353 Digital Camcorder
Go to this link and you can download the manual, drivers and software for your camera - everything that would have been on the cd rom. just download these and follow the installation instructions; http://www.samsung.com/ca/support/productsupport/download/Model_Select.aspx?type=&typecode=200500&subtype=&subtypecode=200501&model=SCD353&fileType=UM&language= Hope this helps, ask again if you have any questions :)
SOURCE: my sidekick 2 camera won't work (someone please help)
There is a hardware problem with some SK2's that involve the top bumper and a brownish ribbon cable under 2 tabs. here's the hiptop forum (the manufacturer) where the problem is discussed,a nd the solution is copied and pasted below. http://www.hiptop.com/forums/viewtopic.php?t=22867&highlight= the problem is that the plastic clips that hold part of the top rubber bumper push on a cable inside the unit. if you take off the top rubberized bumper you will see a orangeish yellow ribbon cable. this is whats getting hit. here are some CRUDE pics i just drew up just now. no laughing! labels these two show what happens after pressure is applied to the area around the sim slot. I found that if you take off the bumper and LIGHTLY massage the side of the cable in with a paperclip (CAREFULLY) and then try the camera untill it works again. then to prevent this from happening again... I cut the clips that go into those holes. no clips.. no issue. ive done this for my freinds and they love me now.. they call it the clip snip. Ive fixed 7.. no 8 cameras so far this way. no where near a software issue. I cannot recomend that YOU sticka paperclip inside the unit unless you know what youa re doing. I can only recomend that you try removing the top bumper and waiting to see if the camera ever comes back. if it dies then snip the clips that go into the hole above the camera cable. let me know if this makes sense to you or not so i can edit.
SOURCE: Panasonic mini dv camcorder cannot get it to view video on my pc
I solved the problem on my own. On the panasonic.com site I searched and found my mini dv camcorder and then I found the software I would need to make it work on the computer. I found everything I needed and I will not need to join the premium plan you offer, sometimes if we just take time you can find it yourself without paying so much for something are there any sites that just help people instead of wanting your money....
kwazegirl
Sounds like your battery is bad
