SOURCE: Only the left ear bud has sound
Hey NoRightSound,
If your earbud headphones function normally with other devices, there are a number of reasons why this problem may be occurring, including faulty connections within the iPod itself or a potentially defective headphone jack. While both of these issues can typically be resolved fairly easily, I would first suggest contacting your local Apple-authorized service center for a complete diagnostic to pinpoint the exact cause of the problem.
Remember that if your iPod is still under the original manufacturer's warranty, you can always call Apple directly for technical support over the phone in addition to working with a technician in your area.
Hope this helps you out.
Sincerely,
Aaron
Go Ahead. Use Us.
SOURCE: Two-Way Radio LI 5650 WXC -> ear bud doesn't work
Did you try plugging in the audio device before turning on the radio? If so, follow this by pressing the PTT on the radio once. It should clear the problem.
SOURCE: my skullcandy earphones are busted
could be caused by the way you wrap them up the cords should never be wound tightly it causes a short and it just so happens that earphones are made of light weight wiring to make them seem to disapear when wearing them so what to do is instead of winding them when your done simply fold them loosely so to speak
SOURCE: just bought a used 2004
Have you tried disconnecting the unit from power to reset it? That should get your radio back and allow you to try pairing, again.
SOURCE: oakley orokr ear bud repair
It will normally be the wires that run through to the speakers, I have 20 replacement wires, its not easy to replace. I offer a set price of $50 to repair them if you are interested. I also have the replacement batteries and lenses
