Across the bottom of my sansui 19 tv screen is a 2 high banner that says Hdtv, dolby, on\sleep timer,pc in,hdmi,eco, and each of those little boxes alternately expand , blocking much of the picture. I need to get rid of it.
SOURCE: Sansui - BOTTOM OF SCREEN CUT OFF
Your problem is not a vertical alighnment or size adjustment. No, Im sorry to say its the old vertical output IC and /or the small capacitors around the ic and in the vertical circuit. If you dont have the right tools, like a soldering iron a multimeter know how to read a schematic diagram, then you should seek out a repair person to assist you in this repair.
SOURCE: Black box in middle of screen
You have CC (closed captioning) turned on and it is set to text mode.....Go to the menu on the remote use the right arrow and hilight "C.CAPT",use the down arrow to highlight "C.CAPT",use the right arrow and highlight "off" then exit button on remote.
SOURCE: Sony HDTV flat - no picture with HDMI cable and Verizon FIOS box
Probably a handshake problem with the cable box. It is common for cable boxes to have HDMI handshake problems. Hook the box up using the component cables and you should be fine
SOURCE: NEED A CODE FOR SANSUI 19" HDLCD1908 TV
Sansui Television 1023, 1107, 1122, 1273, 1382, 1383, 1384
Try one of these yet?
SOURCE: Toshiba TV fails to recognize HDMI input
If the tv does all those symptoms but after some seconds the tv works and stays doing the job. THen the tv has a slow microprocessor to recognice the different resolutions or video inputs.
But if the tv cannot do anything and stay aout of signal forever. send the tv to the waranty. (no waranty? you have to use the component input instead to have digital signal reproduced
