Sorry to read this about your tab.
You may have to Hard Reset your tab once again to see if the unresponsive screen will start responding to touch.
Attempt hard reset for a couple of times (in case once does not correct this fault; alloe small time intervals in-between while you hard reset your tab)
Hope this helps. In any case, do post a feedback.
All the best.
Isn't this the same problem as this one?
http://www.fixya.com/support/t24390784-pin_no_set_in_error_tablet_now_access
The tablet has no PIN. It is the SIM card for 3G that needs a PIN to access the 3G service.
When you remove the SIM card, the tablet will work perfectly without asking a PIN.
I hope this helps.
SOURCE: how do I bypass pattern lock on my Proscan PLT7223G tablet?
Zolygon Factory reset Proscan PLT7223G Android Tablet
Please watch the video and try the link given
Contact a local phone/electronics service facility for assistance. Cell phone vendors can recommend some in your area if you cannot find one in the yellow pages or on the internet.
SOURCE: Nuvision tablet will not connect to network for Internet access?
I've seen this problem on a lot of lower budget tablets, where no matter what you do the tablet won't connect. Somehow if the miss an update, then you have a firmware problem. Go on a PC and install an android update and firmware app. Choose the tablet that you have and update. Put this on your tablet when it finally connects.
