Televison & Video Logo
A
Anonymous Posted on Jul 24, 2018
I have an RCA RTU 6549 LED tv with vertical streaks in the picture. Whats wrong?
5 Related Answers
Anonymous
  • 790 Answers
  • Posted on Oct 21, 2007
SOURCE: I have the JVC AV-48wp74
ok! you have defctive convergence correction circuit! thats why the color is abnormally function!
J Malick
  • 15 Answers
  • Posted on Feb 23, 2009
SOURCE: RCA 52in stretched picture
1) Do you have a cable box or converter box hooked up to the TV? 2) How old is the TV ? 3) Is it a rear projection TV? 4) Does this happen when watching a DVD, Game Source, VCR Tape?
projdoc
jasbo
  • 2239 Answers
  • Posted on Nov 05, 2009
SOURCE: White vertical streak
what type of projector is it? what model?
Silverdragon
electronic & computer repair& servicre
  • 12061 Answers
  • Posted on May 05, 2010
SOURCE: i have a 42 inch rca tv model WB22YX5 componet inputs dont work
Sometimes, these inputs get damaged by ESD, or stray voltages, and become damaged. You may just need to give the set a reset, unplug an leave for 5 mins or so, and try again, if still no go, see if there is anything, in the troubleshooting procedures, that can help. It may just be a board replacement, If you decide, to get it repaired, please first contact RCA head office, and ask for a referral, to an authorised service center.
http://www.scribd.com/doc/7581822/RCA-Chssis-CTC-175176177186187-TV-Training-Manual
Anonymous
  • Posted on Sep 20, 2010
SOURCE: my RCA model D52W19B tv
I have the same problem with the same tv.
did you get any solution?
Rca tv rtu 6549-c colored horizonal lines when turned on disappears when warmed up
I hate giving you bad news but 99% of the time horizontal lines come from a bad panel, it's time for a new TV
How do I program my xfinity remote to work the power on and off also the volume on my RCA TV model RTU 5540-C
Just to make a note, the RCA 4k UHD TV models such as RTU-**** are horrible for finding remote codes. These TV's are actually made by Curtis. The manua will give you the remote code.. sort of. So far it seems as though all of them are NEC format with a code of A05F .. along with a full key map.. useless for a universal remote, useful for a Windows ore linux serial based IR transmitter.. and maybe a lead to the 5 digit code. NEC codes did not work, seems to be NEC format, which covers 95% of all remotes, NOT NEC product.
RCA LED LCD TV Vertical Line Problem
Sounds like your display driver board is broken. Try claiming warranty.
Why did my Quasar TV (1993) picture go out again, blue line across the screen? We had it repaired, 3 months later no picture, same blue line.
Sounds to me like something else is causing those parts to fail. It should be under warranty but depends on the repair shop. Why not just buy a new one.
Here are some choices for a new one:
RCA 42 LED42C45RQ Class LED 1080p 60Hz 3 4 ultra slim HDTV
Why did my Quasar TV 1993 picture go out again blue line across the screen...
LG 24 Class 23 6 Diag LED 720p HDTV Black
RCA LED32G30RQ 32 720p 60Hz Class LED HDTV Walmart com
Black screen except in the middle. It has a white streak and part of the picture.
Vertical scan output section circuit fault. Contact any service technician, to replace the damaged component/s. To get some details, http://electronicshelponline.blogspot.com/ Pull up older posts.
8helpful
2answers
Dark shadow-like vertical streaks thru LCD screen (Sharp)
Hi, I have a Sony Grand Wega LCD Projection TV that has a blotted gray streak across the front of the screen. I only use a damp cloth to clean the window and that doesn't seem to help. It really shows up on light pictures and is unnoticed when the picture is a little darker. What can I do to fix this problem???
RCA D61W20 Image Turns on and Off
sounds solder related. I would guess the vertical output IC or flyback needs resoldering, As the vertical will shutdown the picture if the solder looses contact, and the flyback feeds the filament voltages to light the tubes. Solder repair is usually the cause when you lose picture but have sound.
Hitachi tv
no picture on tv
19helpful
3answers
Plasma tv vertical lines
I am getting a vertical green line on my lg 50 incs is the screen or have you a solution
Top RCA Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
