SOURCE: sony 3 disc changer mhc-gx880 has broken belt. How
You have to open the unit with screws in the back and push it out by hand, there should be a series of gears that you have to spin for the tray to come out. You may be able to gently push it by hand to come out.
SOURCE: i have a SONY HI FI 'MHC-RG66' mechanical error
kiero saber donde vienen las salidas del estrereo sony mhc rg66
SOURCE: So when I turn on my sony MHC-GX8800 shelf system,
I had a extremely similar problem with that model the only difference is that it used to turn off whenever I put the volume up. Anyway there was a peace of stranded wire behind the speakers terminal block connector, so be sure to check it out.
SOURCE: sony mhc-2600 tape stuck
The tape has spewed out in the mechanical section preventing the door from opening, some outer doors can be removed by too thumb screws sliding up and out, others are held in by plastic clips, the door may have to be pried open to get the outer door off to remove the tape.
SOURCE: Sony music system MHC-GZR77D eject message disply & set is stand by mode
Disc loader mechanism fault. Contact any service technician. The mechanism should be taken out from the set for repair, and this is a skilled work. If you wish to get some details; visit the site linked here. Pull up older posts. http://schematicscom.blogspot.com/
