The service manual for model MMV5165 is here at my Web site.
SOURCE: i bought a used maytag
You can download the owner's manual and installation instructions here.
You can usually find helpful exploded view diagrams and order needed parts by entering your full model number here: http://tinyurl.com/gv383
We're happy to help and we appreciate your thoughtful rating of our answer.
SOURCE: repair an Amana microwave
My amana micro just went dead. No lights nothing ,almost like a fuse blew.Its an over the stove model . The outlet works fine.#mvh210w
SOURCE: Maytag - MMV5165AAS
If it is under warranty, call service. I experienced similar odors, sounds, and failure to heat meals. The magnetron/emitter and the transformer are replaced on two separate failures. Now the third time just happened. I am afraid mine is out of warranty and I will not purchase Maytag again.
SOURCE: No heat from my microwave maytag mmv1153aaw
There
should be a "mini-manual" (tech sheet) hidden inside the unit
behind the
control panel or hidden on the left side behind the grille, which is
very helpful when troubleshooting, testing, and locating components.
You can find
helpful exploded view diagrams and order parts by entering your full
model number from the tag on the oven here.
Here are some links you
or someone you know can use for test help, but read their safety
warnings first:
http://www.gallawa.com/microtech/diode.html
(if it's not shorted or burned, it's
probably okay)
http://www.gallawa.com/microtech/mag_test.html
http://www.gallawa.com/microtech/xformer.html
But if when you start to microwave, if the turntable, inside light and internal light are not on, then you instead have a bad door switch or door switch mount, in which case you should see this:
http://www.microwavedisplay.com/doorsw.txt
We're happy
to help you with free advice and we'd appreciate your thoughtful rating
of our answer.
SOURCE: Maytag MMV5156AAS Microwave won't heat and has hum/buzz.
A failed diode isn't the most common failure, but it happens. And sometimes it's due to bad magnetron or a bad connection.
If the capacitor fails, it almost always shorts, which results in a blown fuse whenever you hit "Start" to run the microwave.
The magnetron on this model should have a 5-year warranty, in case that's relevant. Your owner's manual is here.
We have
the service / repair manual for this model and have uploaded it to our
site here to help you.
It will give you safety info, step by step help in disassembly, troubleshooting tips, and part numbers.
warnings first:
probably okay)
http://www.gallawa.com/microtech/cap_test.html
There
should also be a "mini-manual" (tech sheet) hidden inside the unit
behind the
At
our Web site, we have a video
available showing how to remove a typical
over the range control panel assembly in under 5 minutes.
You can find
helpful exploded view diagrams and order parts here.
We're
happy to help you with free advice and we'd appreciate your
