Question about Nokia Computers & Internet
How can i get my nokia c2-01 from test mode?
When i turn it on it shows white screen and a message that says test mode
  • Nokia Master
  • 1,548 Answers
To exit test mode, turn off phone.
Press *3001#12345#. Scroll up 1 to FIELD TEST (some phones may say NET MONITOR instead of FIELD TEST) and SELECT. Scroll to ENABLED and press OK. Turn phone off and then back on. Signal strength is the upper or lower left number. After test mode is enabled it will stay in your regular menu. To easily get in or out, press MENU, up 1 FIELD TEST and SELECT or OK. Dial 00 to get out and 01 to get back in.
Posted on Jul 27, 2018
6ya staff
SOURCE:
SOURCE: white screen
just format your format your phone using twister/ tornado or jaf box because the software of your phone was corrapted
Posted on Jun 02, 2008
abhishek33
ABHISHEK.C
  • 1239 Answers
SOURCE: tv screen goes black and says string to test text mode?
Hi and welcome to fixya, it is the colour wheel problem,,,,,,,,,this is common problem please check it ...it may be also cathode ray tube... thank u.........
Posted on Jun 03, 2009
fayasonline
fayas salim
  • 92 Answers
SOURCE: Hii My Nokia 5130 Express
please format your phone using first switch of your phone then press the star(*) three(3) and call button holding these button and switch on the screen displays blank white screen for sometimes and then on .
Posted on Oct 20, 2010
Computer Links
  • 2386 Answers
SOURCE: my nokia 2760 will not
Hello
This solution provide some simple tricks on how to diagnose this problem, if encountered that only test mode showed on the LCD screen display, you may try to replace a new battery on the device. If after changing the battery doesn't fix the problem, you may refer to the solution below for it shows the certain components that needs to be remove or replace to fix the problem.
Try to remove or replace the ESD protection diode. This components were composed an ESD protection diode and a capacitor and it result to test mode problem if being damaged.
Hope it helps, if so do rate the solution
Good Luck
Posted on Dec 28, 2010
guru68
  • 347 Answers
SOURCE: I have a Nokia 1209
remove sim
press star and three and on switch together for about 5 sec
mobile will switch on and show hard reset
pls back up ur data (numbers etc)
Posted on Feb 07, 2011
Please how do i on my nokia phone as its showing 'test mode' on the screen?
follow these steps, this might help:
1. turn off your phone
2. turn the phone again
3. then type: *3001#12345#
4. on that scrolll menu, click disable
5. turn it off, then on
hope that helps
Aug 24, 2011 | Nokia 5000 Cellular Phone
I have a Nokia 1209 and it's showing the Test Mode message on the screen. I can't even make a call because of the test mode message. Can you help me?
remove sim
Feb 07, 2011 | Cell Phones
My nokia 2760 will not turn on. it shows only - test mode - on the screen. what is wrong with he mobilphone
Hello
Good Luck
Dec 28, 2010 | Nokia 2760 Cellular Phone
Hii My Nokia 5130 Express Music phone doesnt start up. It shows "test mode" on plugging the charger. Even otherwise, on starting the phone the Nokia logo appears ten the screen goes white and switches...
Oct 20, 2010 | Cell Phones
I just dropped my phone (nokia 2320c) in the bathroom and when I put the battery back in and turned it on it displayed a white screen with the words "test mode" in red. It seems as though my phone is...
If you have a problem of local mode test mode in Nokia 2320 Classic. You can solve this problem by following a few simple steps as given in this post.Lock at the diagram bellow that will help you to solve Test Mode Local mode problem in Nokia 2320 Classic. Before removing this part that is identified with red line in above diagram replace battery and if batter can not solve this issue dis assemble mobile phone. Find parts that are shown in diagram with red lines and remove them to solve Nokia 2320 Classic Test Mod Local Mod. Smartphone Repairing
Apr 12, 2017 | Nokia 2320 Cell Phone
Test mode
hello,please kindly rephrase your question.
thanks,take care.
May 07, 2010 | Nokia 1208 Cellular Phone
White screen
Jun 02, 2008 | Nokia 7610
Show test mode
my handset model1600 shows test mode , how do i turn on phone ?
thanks
Feb 29, 2008 | Nokia 1600 Cellular Phone
White screen with ' NOKIA' written on switching on
there is problem with operatng system of ur phone, take it to any technician so it can be reinstalled .
Feb 28, 2008 | Nokia N70 Cellular Phone
Nokia 5300 xpress music
As I have posted separately there are various problems with this phone, the 5310 is not much better. Stick with it till you can afford a new one and then avoid Nokia. I've been a big fan of Nokia for years, but 2 crap phones later and I'm pretty p'd off!
Dec 26, 2007 | Nokia 5300 Grey Cellular Phone
Computers & Internet Logo
540 people viewed this question
Top Nokia Computers & Internet Experts
Anthony Ward
Anthony Ward
k24674
Ekse
Are you a Nokia Computer and Internet Expert? Answer questions, earn points and help others
