To disable the child lock (control panel lock) on the Electrolux EFDE210TIW, press and hold the Dry Time and Wrinkle Release key pad buttons until the indicator light goes off. These are the two buttons to the right of the LCD screen. You will need to hold the buttons for several seconds (usually between 3 and 10 seconds depending on when the dryer was manufactured).
See page 11 in the user manual. The manual is available on the product page: https://www.electroluxappliances.com/Washers-Dryers/Washing-Machines/Dryers/EFDE210TIW/ . The direct link to the English version of the manual is currently http://manuals.electroluxappliances.com/prodinfo_pdf/Webster/136936001en.pdf .
I hope this helps.
SOURCE: help me to remove the Child Lock
unfortunately Hitachi created these
tv's so that you could only remove the child lock by accessing the menu with the original remote only.
Sorry!
SAM
SOURCE: how do i remove child lock on samsung front loader
Try buttons "dry" & "spin" together for a few seconds. This is the child lock display.
Or press "end of cycle" for over 5 seconds.
Or press "options & select" till the light goes off.
Works for other machines..............And please rate me if helped
SOURCE: Electrolux tumble dryer
Power it down and then restart. Turn breaker off
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
SOURCE: Washer is not draining. How do I remove the front
you will need to remove the lid first then remove the screws that hold the control panel in place.then you will need to remove the door boot on the front panel. there will be two screws on the bottom of the panel that will need to be removed as well as the screws on the top of the panel.
Testimonial: "Thanks so much, really appreciate the quick response!"
Hello Elizabeth P Cochran - Try resetting the unit by unplugging it or flipping the household circuit breaker off. Wait approximately ten minutes and restart unit. If the door does not open, then it sounds like the washer is possibly experiencing a communication problem with the control board, wiring failure or faulty door lock. Contact a professional to move forward accurately to properly diagnose/repair unit.
