Question about Panasonic Televison & Video
Need code for Panasonic remote control dmres47v
5 Suggested Answers
Anonymous
SOURCE: remote control codes
i have a oneforall urc-7530 controll and need a code for a panasonic tv
Posted on Dec 19, 2007
Bob Ze
  • 6 Answers
SOURCE: Need remote code to control a Panasonic Omnivision VHS PV-M2079 TV/VCR combination
You need to program the VCR (which turns the sey on/off) as an aux, then program any Panasonic TV type for TV, and then set the STB button to control STB, TV and AUX and you should be set.
Posted on May 01, 2008
Anonymous
  • 3 Answers
SOURCE: Need remote control code for Panasonic PV-DF2703
I found a newer Comcast PDF file that shows a 5 digit number for tv with vcr ( no mention of DVD) but the code worked to turn on the tv and cable box together. My problem is it won't work the volume, yet
https://www.comcast.com/MediaLibrary/1/1/Customers/Customer_Support/Digital_Cable_with_OD/Digital_Cable/remotes/Remote_M1067BX3.pdf
Posted on Dec 30, 2008
Anonymous
SOURCE: Trying to program Philco URC-2070 remote control
I determined that the Philco Remote Control that I wanted to program for use on a Magnavox tv was too old (20+ Years) and dead. It also did not have the features of a new Universal Remote. So, I tosed the Philco remote and purchased a new Universal Remote Control.
Thanke you..
Posted on Mar 20, 2009
Anonymous
SOURCE: code for universal remote rm-810
There is an easy way to setup this remote controllerl(RC). It called "Automatic Code Searching" which means that you don't have to even find the code. The controller will searching it for you. Just do the following steppes.
1. Turn on the "Device" to be remotely controlled, e.g. TV, VCR.
2. Point the RC right to the "Device" .
3. Press a device button on the RC represent the "Device", e.g. TV, VCR, DVD etc. You can see the indicator lid flash once.
4. Press the SET and than the POWER button on the RC. hold both buttons for 2 seconds or more, you will see the red lid on. then release both buttons simutenously. after that the indicator lid will be flashing, means the searching started.
5. Keep pointing the RC to the "Device" until it is shut down by the RC, Press any button in 1.5 second to finish the setting.
You can try the RC now. It should work. My one is working.
Posted on Apr 09, 2010
Im trying to program a Panasonic universal remote to clear tunes tv
Search Results
    Need codes for ct-300 clear tunes universal remote - Fixya
    www.fixya.com/.../t17341079-need_codes_ct_300_clear_tunes_universa...
    Mar 26, 2013 - need codes for ct-300 clear tunes universal remote Need codes - Symphonic ST419E TV ... Universal remote code for a panasonic ct-27g14a.
    I have a clear tunes tv and trying to program my RCA universal
    www.fixya.com/support/t25649135-clear_tunes_tv_trying_program_rca
    Apr 16, 2015 - ... a clear tunes tv and trying to program my RCA universal remote to it ... "I need to program an old Panasonic TV with a RCA universal remote ...
    I need the codes to a clear tunes remote for a rca - Fixya
    www.fixya.com/support/t3026751-need_codes_clear_tunes_remote_rca
    Sep 26, 2009 - I need the codes to a clear tunes remote for a rca tv. ... "I need toprogram an old Panasonic TV with a RCA universal remote model RCR311St ...
    Radio Shack panasonic remote control codes clear tunes tv ...
    www.fixya.com > ... > panasonic remote control codes clear tunes tv
    ...remote. the panasonic codefor my radioshack 3-in-one remote is 0250 I need a codefor a VCR Durabrand (DCV603) for the Sony universal remote control or a ...
    Clear tech tv 4 digit code - TV - Other Consumer Electronics
Jan 25, 2016 | Panasonic Televison & Video
How to get Panasonic BlueRay remote (N2QAYB000734) to operate Hitachi TV
If the remote is programmable, you should be able to search for the code.
Mar 28, 2014 | Redi-Remote PANASONIC Replacement Remote...
Remote codes panasonic tv for onyko rc-693m
What you really are requesting is the Onkyo remote codes to control your Panasonic TV. The code comes from the remote, not the TV
Dec 04, 2012 | Onkyo RC-693M Remote Control Part 24140693
PHILLIPS UNIVERSAL REMOTE CL032 NEED CODE FOR PANASONIC TV
Panasonic 0 0 5 1 ,0 2 5 0 ,0 0 5 5
try those
Please rate opur help to keep the FREE service online ++++
Aug 31, 2009 | Philips PM3S Remote Control
Need code for urc-3220 for panasonic tv
I can help you to program your One For All Big Easy URC-3220 Universal Remote to control your Panasonic TV.
Please review my Fixya Tip posts for:
  1. Searching for the proper codes, or
  2. Downloading the URC-3220 users manual / owners guide. This contains all the codes for the brands of devices your remote can control.
I hope that helps.
Aug 09, 2009 | One For All URC4110 Remote Control
I have a rca universal remote control and I need a code for a panasonic tv
Code For Model RCR350
Code 1003 for Panasonic TV Code 1054 for Panasonic TV Code 1062 for Panasonic TV Code 1109 for Panasonic TV Code 1170 for Panasonic TV Code 1248 for Panasonic TV
Aug 05, 2009 | RCA RCR350 Remote Control
I'm using Ellies universal remote, I Need Code for Panasonic Tv
I'm using Ellies universal remote, I Need Code for a Sonic television
Jul 15, 2009 | Panasonic Televison & Video
Codes for a panasonic LssQ0263 universial remote for a Rca TV
I need to program old TV RCA with Panasonic universal remote comtrol
Jun 17, 2009 | Panasonic DBVSQ-W0044 Remote Control
"I need to program an old Panasonic TV with a RCA universal remote model RCR311St Help""I need to program an old Panasonic TV with a RCA universal remote model RCR311St Help"
Code For Model RCR311S Code 1003 for Panasonic TV Code 1054 for Panasonic TV Code 1062 for Panasonic TV Code 1109 for Panasonic TV Code 1170 for Panasonic TV Code 1248 for Panasonic TV GOOD LUCK THESE ARE THE CODES LISTED FOR YOUR REMOTE/
Jun 03, 2009 | RCA Universal Remote Control
Code search for Panasonic Tv on Universal remote
i need code for panasonic tv with zenith remote control
Jun 28, 2008 | Televison & Video
Televison & Video Logo
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
