SOURCE: hi there my allen heath mixer is weired this
If you use analog outputs and inputs try to clear of it really is your mixer and not one of the inputs. If the inputs are good your mainboard could be a bit dusty or you have a loose contact. If you have a mixer with internal interface your audio stream from your computer might be the problem.
SOURCE: I would like to buy
Cases are being sold on Ebay, new, from several sources, and if you can't find one specifically listed for your unit, contact the sellers as they custom build them. That is a big unit... expect to pay around $150 to $200 for an ATA type case for it.
Here is an example for a Heath/Allen 420. http://cgi.ebay.com/ATA-CASE-ALLEN-HEATH-ZED-420-ZED-420-ZED420-MIXER-/400127078772?pt=LH_DefaultDomain_0&hash=item5d296eb174
I have bought from them before myself and there are others on Ebay so shop around... You can contact the companies and ask for a specific one and DO compare the size to your unit that they specify as all the companies do not accept returns...
SOURCE: I have 2 mic channels on my Allen Heath AP7880_1+ZED10 that are not working...input issues, or?
input issues, probably cracked solder joint
http://www.allen-heath.com/media/AP7880_1+ZED10_UserGuide_A5.pdf
SOURCE: I have 2 channels on my Allen Heath AP7880_1+ZED10 that are not working...input issues, or?
input issues, cracked solder connection
