SOURCE: Maytag Nepture MAH5500BWW burned control board
ummmm, honestly ive never replaced just the board(im an authorized maytag servicer) so our replacements have always been new, and in this case the repair kit containing both board and motor. that being said, i cant see a reason as to why you couldnt relace just the board itself, ,Ireally never found the reason why the board would burn out, but, as far as repair kit im certain that they were trying to get all circuit boards and motors back to only one model, instead of having 5 or six different boards andmotors, this will bring them all to the most recent board and motor, never was an issue with themotor, jusat that you couldnt wire in the new board without the neew wiring. As long as its the same board i cant see why that wont work. as far as the "wax motor" that was a seperate issue burning out the Top control board, total seperate then your problem,., dont really see an issue with installing your "used board"
SOURCE: prong on dryer plug gets hot and burns plastic on plug
You are right. There is not a good connection somewhere. When you say your replaced the cord, did you also replace the plug? Make sure all fittings are tight. Where it is melting, this is where the problem probably is. You can also check the receptacle and see that the wires to it are tight as well. There is a build up of heat or resistance in that area tha tis causing your problem. let me know how you do. Good luck.
SOURCE: Replacing Control Board on Frigidaire model LEQ1442ES0 Dryer
There should be screws on the back side of the top panel that come out. Then the panel will slide out so that you can access the front controls.
SOURCE: MY FRIGIDAIRE ELECTRIC DRYER IS LEAVING BURN MARKS
Assuming that you have the correct temperature selected for your clothes, there are two likely causes:
If the clothes are showing randomly shaped burn marks, the dryer is overheating. This would be accompanied by a burnt smell on the clothes. The high limit thermostat is the culprit.
If the burn marks are dark streaks, the clothes are getting pinched between the drum and the inside of the dryer that does not move. This is caused by worn bearings, slides or rollers. Should you choose to repair this yourself, there is a great deal on a kit with all of the parts you need plus a new belt for only $32 here:
http://www.repairclinic.com/PartDetail/Drum-Bearing-Felt-Seals-Pulley-Belt/5304461262/1261075
Good luck from Detroit, Mi.
