SOURCE: no sound with ps3, connected to a 7.1 av receiver & projection tv
Hi...the HT-R800 Home Theater system has the HT-R550 receiver which could only carry Video via HDMI. you would need to connect a separate audio cale(Optical Audio Cable) to be able to get audio out of the PS3 to the receiver. Once you have hooked up an Optical Audio Cable you would need to go in the PS3 setup and putin Bitstream and Optical in the Audio Setup menu.
SOURCE: My panasonic th-42ph11uk isnt powering
Maybe the power supply is the problem of your television.Either it is loose connection in power supply circuit.Its need to resolder the loose connection and cold solder of the power suply circuit..
SOURCE: Panasonic TV Receiver problem
It will be best to contact the authorized service centre for Panasonic in this case.
Testimonial: "I'm afraid so, they have came but no solution they said. They told me to buy the receiver's processor, do you have any idea where to get it?"
