Toshiba SD-4100 DVD Player Logo
Posted on Aug 02, 2009
Dvd will not load just keeps flashing loading This includes any type of dvd. Anyone have an idea to get this thing running?
Anonymous
Level 1:
  • Contributor 7 Answers
  • Posted on Aug 03, 2009
Anonymous
Contributor
Level 1:
Answers
7
Questions
0
Helped
8010
Points
44
Try a few different types of media....if still no luck then your going to need some laser servicing or possibly replacement. same old same old im afraid. if the unit is more than a couple of years old then be carefull how much you spend for a service. may not be worth it.
Dymo labelwriter 450 was working perfectly under Windows 10, but now keeps saying out of paper. Labels are genuine Dymo, right way round, correctly positioned, but blue light keeps flashing.
A flashing blue light means the printer has either run out of labels or the labels are not loaded properly.
Since you are sure the labels are not run out the only thing it can be is the labels are not loaded properly, double check the loding.
2helpful
2answers
Loading keeps blinking Nothing works anymore. even power of no longer works
Check for dried up electrolytic capacitors on the DC-DC converter C5318, C5340, etc.
1helpful
Water will not drain - rinse hold/mini load lights flashing
You might have to take the pump off and clean out the debris in the line theres probably lint, change and other things in the line. Take the lines off and run a piece of wire through the lines to make sure their clear.
Portable dvd player won't work
As I recommend to anyone having problems of this kind; you need to procure a cheap multimeter so you can at least check whether your adapter is producing any voltage at all and check the battery to see if it is even chargeable; these things will short one or more cells making them unusable and incapable of taking a charge.
You can buy a digital multimeter for under $20 US at Radio Shack or auto parts stores, or under $10 US at Harbor Freight Tools if you have on in your area. They include almost intelligible instructions in Chinglish.
Disc gets stuck on "loading"
laser lens may need cleaned or realind! claen and try again
1helpful
Keep saying loading than just ejects the dvd all types of them
It has problem in dvd loading mechanism which is not load completely and mean while system control IC waits for complete loading signal and than produce eject command.
You need to open top cover and check closely its DVD Loading Mechanism, might be loading belt slips.
2helpful
My dvd recorder will not play or record
ARE YOU TRYING TO LOAD A PROPERLY FORMATTED DISC??? IS THE DISC PLAYABLE ON ANY OTHER DVD IN YOUR HOME??? HAVE YOU RUN A LENS CLEANER IN YOUR SYSTEM??? HAVE YOU PREFORMED A SYSTEM RESTORE BEFORE THIS STARTED?
1helpful
2answers
Player won't load any discs
I don't have a solution at this time. I have the same DVD player and mine stopped working this past weekend. It is doing the same thing as yours. I opened the case and loaded a disc and watched the mechanism. The disc won't spin. if you tap the disc it will start spinning and load and start playing. I thought I had fully fixed it. It will load most times but now the video and audio stutters as if the discs is spinning at varying rates.
Help
Hey I bought the same exact thing open box missing same stuff. Manual is online at http://www.thomsonnetwork.com/EN/Public
I have same problem with USB. Have you found out how to get a replacement for the MP3? or maybe model # for mp3?
Whirlpool LTE5243D Top Load Stacked Dryer heats sometimes and not others
couple things this could be lets start obvious
faulty door switch even though door latches doesnt mean its working properly
bad guages easy to check dont have to run dryer just guages
turn on setting let run threw cycle if it stops on cycle and dont move for a length of time this will be the problem
these 2 things are main causes of why a machine wont work or partcially works at times everything else is easy
Top Toshiba Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
