SOURCE: 12v drill/driver not holding charge
Seems like your batteries need to be repaired and recharge! For this, let me suggest you the ultimate Nicad battery repair guide. This is very efficient and works on all weak or dead nicad batteries. With this nicad battery fix manual, you can repair, recharge and make your old batteries work like new ones. it is easy to understand and easy to work on. Recharges the batteries within no time. Try it, it is really helpful!
SOURCE: dewalt base charger unit
. The light on the charger will blink on and off during the charging process and will remain on when the charging process is completed.
SOURCE: I HAVE DEWALT CHARGER DE9116.ITS OUT PUT VOLTAGE
check output voltage on charger label most chargers are not regulated so if it says 18 volt output it may put out 24 volts but if its putting out 51 volts it may have a short batteries will get warm but not hot replace charger
SOURCE: HELLO: OUR MILWAUKEE 48-59-2401 BATTERY
If both lights are flashing after you put a cool battery on the charger, the battery is bad. It could have a bad, worn or shorted cell or other problems inside and the charge will not charge it as long as it reads it as a bad battery. Rechargable batteries do have a finite life determined mainly by how many times you recharge them.
SOURCE: My DeWalt DW9116, battery charger lead light is fl...
Brown
Brown
Silver
Gold
R21 = 0.11 Ohm at 5 percent
Now can someone help me find the schematic for this model? DW9116
[email protected]
On 3/5/12
