Question about ASUS Televison & Video
How do I unlock & change a region area number on my new Asus DVD external driver/Recorder.
Anonymous
SOURCE:
devocap
Devocap
  • 201 Answers
SOURCE: UNLOCK REGION CODE FOR PHILIPS DVDR3475/37 Recorder
Your device is designed for playing back region 1. It will also playback disks recorded with a region setting of all. The region setting of the device is fixed. Also it will only playback NTSC, and not PAL . This is also fixed on your unit. Sorry I could not bring you better news. However there are many burning and conversion programs you can use on your computer (ie Nero Vision, ConvertXtoDvd,..) which provide you the optional settings you are looking for, and allow you to burn in the setting you choose, allowing for playback on your Philips device. Good Luck!
Posted on Feb 07, 2008
jaffa012001
L Jefferson
  • 376 Answers
SOURCE: philips dvdr 3320 v DVD Player Unlock region codes
In DVD mode, press System Menu
Go down to the "Lock " icon
While lock is highlighed press zero "0" for 7 times ( i.e 0,0,0,0,0,0,0)
There will be pop-up window that asks you confirm. Press "OK"
Posted on Aug 12, 2008
Anonymous
SOURCE: region free - Samsung DVD-VR375 DVD Recorder / VCR
I have managed to get a solution to this now. I have a region 4 as in Australia so depending on where you are you'll need to try the correct region. It worked for me first time. Point 4/ below my region code appeared in the top right corner for a couple of seconds not the top left! Once you've completed below turn the machine on again and stick in one of the dvds that would not work before.
Cheers Stewart
1/Turn machine on without disc inside
2/Press menu button
3/Enter region code (See below for list)
4/A highlighted 'region area number' will appear in the upper left corner (some players)
5/Press 9 to change the region number to multi-regional
6/Turn machine off
R1 - 29334
R2 - 38767
or, 5 7 5 3 8
R3 - 56732
R4 - 76884
R5 - 53814
R6 - 24462
Posted on Sep 19, 2008
jaffa012001
L Jefferson
  • 376 Answers
SOURCE: region free unlocking code for LG RH2T80 DVD Recorder
Goto 'Setup'
Scroll to 'Lock' (don't scroll sideways from here)
press '0' seven times
press 'Enter'
Posted on Oct 19, 2008
Anonymous
  • 3 Answers
SOURCE: Region code 4 on Samsung DVD-VR355 player/recorder
I live in Australia and have two Samsung DVD/VCR player recorders, DVD-VR375 and DVD-VR355. I could only play Region 4 DVDs until I pressed DVD, with no DVD in the units, pressed Menu then 76884, then 9, inserted a Region 1 DVd and it played in both units.
Christina Weate
Posted on Jun 13, 2009
Want to unlock region codes on my Samsung vcr/dvd recorder model no dvd-vr375 so I can record here and it can be played in Canada
Do the following step to make your DVD player region free..
1.Turn machine on without disc inside
2.Press menu button
3.Enter region code (See below for list)
4.A highlighted 'region area number' will appear in the upper left corner (some players)
5.Press 9 to change the region number to multi-regional
6.Turn DVD off (remove power from mains)
next time when u power on the DVD ,it will be region free.
region 1 - 29334
2 - 38767 or, 5 7 5 3 8
3 - 56732
4 - 76884
5 - 53814
6 - 24462
ok
Jan 22, 2011 | Samsung DVD-VR375 DVD Recorder/VCR
How do i unlock the region code
2/Press menu button
6/Turn machine off
R1 - 29334
R2 - 38767
or, 5 7 5 3 8
R3 - 56732
R4 - 76884
R5 - 53814
R6 - 24462
Jan 02, 2011 | Samsung DVD-VR375 DVD Recorder/VCR
Can a region 1 DVD be played in australia
DVD-VR330: region free
1.Turn DVD player on without a disc inside
2.Hit 'MENU' on remote control
3.Enter code: 57538
4.The current region code will be displayed in the top-left corner
5.For region free press 9 (region 2 UK, region 1 US etc)
6.Power OFF and power ON
Remember your region code that displayed.Some disks sold in your area will only play if your unit is set to your region.In that case go thur process again and instead of 9 put your region number in.Need more help majortom350@yahoo.com.
Aug 22, 2009 | Samsung DVD-VR330 VCR and DVD Recorder
Samsung DVD-VR375 - can't chage from region 1 to region free
I used this and it worked for me!:
2/Press menu button
6/Turn machine off
R1 - 29334
R2 - 38767 or, 5 7 5 3 8
R3 - 56732
R4 - 76884
R5 - 53814
R6 - 24462
Jun 20, 2009 | Samsung DVD-VR375 DVD Recorder/VCR
Need to unlock the region code so that I can play Australian DVD's on UK machine
Go to videohelp.com and search on the model number - the sequence of remote control keys to press to change the region code is there. It worked well for me, so I could play US DVDs on my UK region machine.
May 08, 2009 | Samsung DVD-HR730 DVD Recorder/HDD...
Making dvd player region free
2/Press menu button
3/Enter region code (See below for list) eg if your present region code is R1 enter 29334
6/Turn machine off
R1 - 29334
R3 - 56732
R4 - 76884
R5 - 53814
R6 - 24462
Oct 16, 2008 | Televison & Video
SANSUI UNLOCK REGION CODE DVD RECORDER SAN6C05
Could you please provide us the recorder model number please?
thanks,
Oct 13, 2008 | Televison & Video
Region free - Samsung DVD-VR375 DVD Recorder / VCR
Cheers Stewart
2/Press menu button
6/Turn machine off
R1 - 29334
R2 - 38767
or, 5 7 5 3 8
R3 - 56732
R4 - 76884
R5 - 53814
R6 - 24462
Aug 13, 2008 | Samsung DVD-VR375 DVD Recorder/VCR
Would like to unlock region codes from dvd/hdd combo recorder
hi
you can try to change the region to play using your dvd by highlighting your dvd drive in the my computer folder then click on properties from there you will get to see the region tab and you can change the region setting for the dvd you will be using. but you will only be allowed to change region 5 times
Jun 12, 2008 | Medion Computers & Internet
Televison & Video Logo
71 people viewed this question
Top ASUS Televison & Video Experts
Steve Sweetleaf
Steve Sweetleaf
B.Th. Pluijm
B.Th. Pluijm
Lawrence Oravetz
Are you an ASUS Televison and Video Expert? Answer questions, earn points and help others
