SOURCE: Model TC-32LX700 Power indicator light on from is
Problem is caused by voltage irregularity. Pulled plug for an hour and then plugged it back in. TV reset and it works fine. If this does not work it needs a TV technician.
SOURCE: Panasonic plasma 50PZ85 power led blink 10 times
Either a bad power supply or a bad processor board.
A Good Service Shop should know what the 10 blinks are indicating.
May be a repair cost between $200 and 400 dollars.
Be prepared -
Blessings,
A/V Media Guy
SOURCE: plasma 50 inches dont turn on
The power supply board is dead.Tries the websites like Shopjimmy.com,Ebay.com to buy the refurbish power supply board for the replacement.
SOURCE: 10 red blinking lights on my Panasonic Plasma TV,
This is a power supply issue - found a company that has used power supplies, they sell them for $60.00. We recommend a professional install the board because the voltage needs to be adjusted after the install or you could damage something else. The high voltage in the set can KILL you soe be very careful. The web address for the PS board is plasmafix.com.
SOURCE: Panasonic viera Plasma TV model TH-P42X10A The tv
The power supply board of the television is dead, u know basic electronics' and soldering? Most of the times, the power supply board just have dead leakages gases capacitors.These capacitors always bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get your TV power stable,and work again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
I hope this will help in solving the problem....
