Question about Yamaha Music
My Yamaha PSR 2000, when turn on it show a blank blue screen. Sometimes the "unexpected error" appear. I had to turn it off and on many times before it can be turn on. What is the problem?
6ya staff
SOURCE:
Anonymous
SOURCE: Do you have yamaha keyboard psr 2000 spare parts?
My keyboard yamaha psr2000,so I want parts silicone rubber keypad 61 and including electronic board,thank you.
Posted on Feb 14, 2010
narwalanand
SOURCE: yamaha psr s900 screen/display gone bad
MR SATISH IF YOU WANT TO SOLVE THIS PROBLEM CONTACT:9887070565,94136768(ANAND NARWAL)FROM RAJPUTANA ENTERPRISES
Posted on Aug 07, 2010
jay767
Adolfo Espinas
  • 386 Answers
SOURCE: My Yamaha PSR-S900 screen just went blank when I
Hi Good day!!! what operating system you use?
Posted on Nov 24, 2010
Joe Hogan
  • 10865 Answers
Hello Oker.... Here is a link that you will find valuable http://www.yamaha.co.jp/manual/english/result.php
This will give you the manual for your Yamaha.
Here is an excellent link to PSR tutorials
http://psrtutorial.com/
And here is another necessary link
http://www.bing.com/search?q=Yamaha+Psr+S900&FORM=QSRE5
And here is a link to a free driver [the installer media refered to in the stated problem]
http://diplo-driver.com/download-driver/YAMAHA/PSR-S900-S700
You will have to use a laptop or a desktop computer to download the driver and send it to the keyboard through a USB cord. Joe
Thanks for choosing Fixya!
Posted on Dec 30, 2010
John McPherson
  • 1212 Answers
SOURCE: Repairing Yamaha psr-12
If the power adapter is not the original adappter- check to make sure the polarity is correct- it should be marked on the keyboard near the adapter socket, and also on the adapter itself.
The keyboard should have an internal fuse- check that. Then with keyboard open, if the fuse is okay, trace the power flow from the power pack and look for broken wires, bad solder connections, stressed components like bulging capacitors, etc. It may have a burned out zener diode in the power supply regulator portion of the main circuit.
Posted on Mar 30, 2012
Manual for PSR 270 KEYBOARD
Yamaha has the manual for the PSR-270 keyboard on the product site: http://usa.yamaha.com/products/musical-instruments/keyboards/digitalkeyboards/portable_keyboards/psr270/ . Click on the support tab. The direct link to the manual (in English) shows in my history as: http://download.yamaha.com/api/asset/file/?language=en&site=usa.yamaha.com&asset_id=35052 .
I hope this helps.
Jun 03, 2016 | Music
PSR e423. Why does it have a blank screen and no sound?
Blank screen and no sound, can occur because of damage to the power supply circuit in the PSR-E423.
Circuit power supply is still working but the voltage is not sufficient. This is indicated by a lit LCD screen but does not appear any character, and the sound did not exist. It is a matter of hardwares, so it can not be reset by software.
Should be fixed to the experts.
Do you use the original adapter? Also check the voltage.
Maybe, it is not known why, a voltage adapter has been dropped.
Aug 25, 2015 | Yamaha Music
I have a Yamaha PSR 2000 keyboard. You can not see the keyboard. It lights up but you can not read anyting on it. It is blank. Can it be replaced what part would one need to fix the problem? I had scr
If you have a light behind the screen then the backlight is working. It could be a connection from the board to screen but this is very unusual.
These screens have been know to fail and will need replacing.
HOWEVER
The screen is not a simple and requires an extra driver board and various components to be replaced/changed. You will need soldering equipment for surface mounted resistors etc if wish to undertake this.
The replacement kits including the screen cost around £ 400.00
Have you tried a factory reset?
Hold down top / highest white key whilst turning the keyboard on.
Good luck
Jan 05, 2015 | Yamaha Music
Psr s700 display has been changed colour blue then display is blinking what is the problem
change the whole screen the on capacitor 344 & 544 add resistor with value 2.2k, it will help your keyboard stay longer.
Aug 07, 2014 | Yamaha PSR-S700 ARRANGER WORKSTATION...
My yamaha psre323 does not connect
I have a PSR-E323 and to connect it with my pc using a MIDI connector should i install driver from http://download.yamaha.com/usb_midi/ ??? I tried to install that.. An error msg popped up... error 25001 no device is connected. connect a device and try again. If the "found new hardware" wizard appears push the cancel button...What should I do?? Help me pls...
Apr 10, 2012 | Yamaha PSR-E323 Keyboard
Yamaha psr s900 screen/display gone bad
Jul 22, 2010 | Yamaha Full-Size Keyboard
Feb 12, 2010 | Yamaha Full-Size Keyboard
Music Logo
85 people viewed this question
Top Yamaha Music Experts
Michial Gueffroy
Mike
Are you a Yamaha Music Expert? Answer questions, earn points and help others
