SOURCE: samsung side by side refridgerator making noise and freezing
its a heater cycle problem..the defroster is not working properly. its building up ice in the evaporator that touches the evaporator fan that makes that loud noise but stops when you open a door. it could be either a bad heater, a bad thermo disc or a bad timer.hope i was able to help
SOURCE: Samsung fridge RS2545SH every 7 days freezes fridge coil.
Hey how yo doing? on most refriderator there are two important parts to keeping freezer from freezing over, they are the bimetal thermostat and ice pipe heater. The bimetal therostat is a preset thermostat that ranges from 54degrees farenheit to about 60, when the coils (inside the freezer compartment behind the back panel) reach the preset temp. it closes a circuit and send electricity to the ice pipe heater, to warm the freezer coils preventing from freezing over. if any one of those components fail, your freezer will continue to freeze solid until there is no more space for ice to build on coils decreasing air flow from the evaporator fan blowing air into your fridge.To test you will minor knowledge on using a multimeter.(REMEBER TO UNPLUG REFRIDGERATOR BEFORE SERVICING, IF YOU UNCOMFORTABLE WORKING ON APPLIANCE PLEASE CONTACT A PROFFESIONAL REPAIR SERVICE..) If you'd like to continue please respond.
GOOD LUCK, WORK SAFELY..
SOURCE: Over Chilling Refridgeration set on 7C still goes to 0C Digital thermostat
behind or inside the digital display casing-mike
SOURCE: I ice maker keeps freezing in our side by side GE fridge.
This annoying problem can have a variety of causes. Check these four things first:
If all the above checks out and you’re still getting fill tube freeze-ups,then best get a service guy to take a look. It could be a complicated repair.
SOURCE: fridge barely cool freezer not freezing
I suggest first getting it checked. Maybe there is just a small leak which can be sealed and coolant refilled. If say the compressor is damaged or other major component then only the repair cost will dictate what to do next.
Refrigerators are not very complex and have relatively few parts. You will probably get satisfactory results from repairs.
