SOURCE: RCA Home Theatre Model # P56927, Serial # 026451246
your convergence alignment is off,requires reaignment or possible replacement of module,this type of rca projection tv has a fault with the harness feeding the convergence module there is a fix for it,contact you local rca dealer,they must replace the connector because it bows and looses connection over time that creates other faults also/
SOURCE: RCA rear projection tv
Dir TV projection Techcions, I own RCA Model:P52937 Chassis No.PTK195M26B. After a big flood here in Chicago, my basement got flooded and my projection TV was in water up to 1 foot. Befor I turned it on, I dreid it out perfectly, then, I turned it on, and a couple components from the power supply got burned up to the point where I am not able to read the part numbers that are on it. I was wondering if you have this kind of chassis and model service manual for this projection TV, or conponet part number i location 101 on mother boatd power supply. Thank you in advance, Darius If you prefeer, you may call my cell phone: 773-875-3926
SOURCE: I am running a Panasonic DVD (DV 606D). I just
then just plug the video into the back of the TV and leave the sound to the tuner.
SOURCE: RCA tv snowy sound great picture on cable
If sound is ok with a DVD etc connected via a rear input (connect directly to set and not thru a receiver etc) the problem is not the set.
If using a box unplug it and or a receiver for a while and plug back to see if a reboot will allow the issue to be fixed that way.
Testimonial: "I thank you so MUCH for your time & attention. I did all that b4... I called a tv repair ( not knowing IF I'd hear ANYTHING back here ..as this was my 1st. time..:) They had me give all tv info & called me back..THIS model was FAMOUS for this. They had me UNPLUG tv from the wall...IT WORKED! They said "CABLE" SCRAMBLES the signal! I am SOOO HAAAPPY! Thanks to you ALL!..:) PS. SD., I WILL REMEMBER THIS SITE!..:) "
SOURCE: my home theatre isnt working
Ok my hometheater is not working need help. it saying push power portector wend it on and it dont want to play the DVD. i dont know what to do or tell me what to do.
